RB-5009 Initial Setup and VLAN configuration
Hi all,
I recently purchased an RB-5009 to replace two Netgear switches I have. As I struggled last time http://forum.mikrotik.com/t/rb4011-hap-ac-lite-vlan-configuration/147819/1 setting up my RB-4011 I have been careful this time in setting up my configuration changes one at a time, but seem to be missing some fundamental understanding about RouterOS or the order changes should be implemented. This at some point in my configuration changes kicks me out and prevents further access to the router until it is powered off and reset.
This is my test configuration (which I think should do what I want)
# Topic:		RB-5009 Initial Setup and VLAN configuration Post 1
# Example:		Isolated VLANs with upstream Router, no WAN, no Firewall
# Web:			https://forum.mikrotik.com/viewtopic.php?t=891803
# RouterOS:		7.0.5 Stable
# Model:                RB5009UG+S+
# Date:			2021-11-18
# Notes:		Working example of intial setup and configuration changes.
# Thanks:		Mikrotik
# VLAN Overview
# 1 = Default_VLAN1 NOT IN USE
# 50 = Server_VLAN50 (Management VLAN) (192.168.5.0/24)
# 100 = Back_VLAN100 (192.168.10.0/24)
# 200 = Cabin_VLAN200 (192.168.20.0/24)
# 300 = House_VLAN300 (192.168.30.0/24)
# 400 = Wifi_VLAN400 (192.168.40.0/24)
# 500 = Guest_VLAN500 (192.168.50.0/24)
# 600 = IoT_VLAN600 (192.168.60.0/24)
# Interfaces
set [ find default-name=ether1 ] name=Eth1_SG-2100_Port2
set [ find default-name=ether2 ] name=Eth2_Hammerstein
set [ find default-name=ether3 ] name=Eth3_Backberry
set [ find default-name=ether4 ] name=Eth4_Kodi
set [ find default-name=ether5 ] name=Eth5_UNUSED
set [ find default-name=ether6 ] name=Eth6_UNUSED
set [ find default-name=ether7 ] name=Eth7_UNUSED
set [ find default-name=ether8 ] name=Eth8_UNUSED
/interface vlan
add interface=RB-5009_Bridge name=Server_VLAN50 vlan-id=50
add comment="All network ports" name=LAN
add comment="VLAN Trunk to SG-2100" name=VLAN_Trunk
add comment="All Server_VLAN50 devices" name=Server_VLAN50
add comment="All Back_VLAN100 devices" name=Back_VLAN100
add comment="All VLAN devices" name=VLAN
add interface=RB-5009_Bridge list=LAN
add interface=Eth1_SG-2100_Port2 list=LAN
add interface=Eth2_Hammerstein list=LAN
add interface=Eth3_Backberry list=LAN
add interface=Eth4_Kodi list=LAN
add interface=RB-5009_Bridge list=VLAN_Trunk
add interface=Eth1_SG-2100_Port2 list=VLAN_Trunk
add interface=Eth1_SG-2100_Port2 list=Server_VLAN50
add interface=Eth3_Backberry list=Server_VLAN50
add interface=Eth2_Hammerstein list=Back_VLAN100
add interface=Eth4_Kodi list=Back_VLAN100
# Bridge
add admin-mac=00:00:00:00:00:00 auto-mac=no name=RB-5009_Bridge vlan-filtering=no
add bridge=RB-5009_Bridge frame-types=admit-only-vlan-tagged ingress-filtering=yes interface=Eth1_SG-2100_Port2
add bridge=RB-5009_Bridge interface=Eth2_Hammerstein pvid=100
add bridge=RB-5009_Bridge interface=Eth3_Backberry pvid=50
add bridge=RB-5009_Bridge interface=Eth4_Kodi pvid=100
/interface bridge vlan
add bridge=RB_5009_Bridge tagged=RB-5009_Bridge,Eth1_SG-2100_Port2 vlan-ids=50,100,200,300,400,500,600
add bridge=RB_5009_Bridge tagged=RB-5009_Bridge,Eth2_Hammerstein vlan-ids=100
add bridge=RB_5009_Bridge tagged=RB-5009_Bridge,Eth3_Backberry vlan-ids=50
add bridge=RB_5009_Bridge tagged=RB-5009_Bridge,Eth4_Kodi vlan-ids=100
# IP Services
add address=192.168.5.250/24 interface=Server_VLAN50 network=192.168.5.0
add disabled=no dst-address=0.0.0.0/0 gateway=192.168.5.1 routing-table=main suppress-hw-offload=no
add name=BACK_VLAN100-dhcp ranges=192.168.10.101-192.168.10.199
add address-pool=BACK_VLAN100-dhcp interface=RB-5009_Bridge name=TMP_DHCPSVR
add address=192.168.10.0/24 dns-server=192.168.10.1 gateway=192.168.10.1 ntp-server=192.168.10.1
set allow-remote-requests=yes servers=192.168.5.1
/ip cloud
set update-time=no
# Firewall
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=established,related,untracked disabled=yes
add action=drop chain=input comment="defconf: drop invalid" connection-state=invalid disabled=yes
add action=accept chain=input comment="defconf: accept ICMP" disabled=yes protocol=icmp
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" disabled=yes dst-address=127.0.0.1
add action=drop chain=input comment="defconf: drop all not coming from LAN" disabled=yes in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept in ipsec policy" disabled=yes ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy" disabled=yes ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related disabled=yes hw-offload=yes
add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=established,related,untracked disabled=yes
add action=drop chain=forward comment="defconf: drop invalid" connection-state=invalid disabled=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new disabled=yes \
    in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes ipsec-policy=out,none out-interface-list=WAN
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
# System
/system clock
set time-zone-autodetect=no time-zone-name=Pacific/Auckland
/system identity
set name=RB-5009
/system ntp client
set enabled=yes primary-ntp=192.168.5.1 server-dns-names=nz.pool.ntp.org
/system ntp client servers
add address=192.168.5.1
/system package update
set channel=testing
/system routerboard settings
set cpu-frequency=auto
/tool mac-server
/tool mac-server mac-winbox
/ip ssh
set strong-crypto=yes
Any thoughts or feedback on whether the script should work as expected or any glaringly obvious problems / errors?
EDIT: FYI I already have a pfSense firewall providing Internet / IP Services / Routing / VLANs which is connected to an existing RB4011 (with VLANs) the RB-5009 will connect to the 2nd LAN port on the firewall, so basically only need the access ports, trunk and IP address for the management VLAN (Server_VLAN50 / 192.168.5.250/24) so I can replace the existing Netgears with the RB-5009.
The glaring stuff is this:
/interface bridge add admin-mac=00:00:00:00:00:00 auto-mac=no name=RB-5009_Bridge vlan-filtering=no
MAC address like this is never going to work.
You should group these by vlan-id not by interface. I don’t know if this will work properly.
/ip pool add name=BACK_VLAN100-dhcp ranges=192.168.10.101-192.168.10.199
/ip dhcp-server add address-pool=BACK_VLAN100-dhcp interface=RB-5009_Bridge name=TMP_DHCPSVR
DHCP-server should go on the VLAN interface, which you haven’t defined, and obviously you need
to add an IP address on it when you do.
I guess your firewall is all disabled because you can’t get anything to work.
Is the 5009 acting as a switch or a router.
In the previous topic, you had a firewall device in between the ISP and the RB4011.
Is that still the case between internet and 5009 and if so what does the firewall provide?
(just identifies vlans)
(identifies vlans and creates the subnets dchp, pool, address etc…)
Hi anav,
The RB-5009 will basically be a switch (with firewalling) and all IP services (Internet, Routing, Firewalling, DNS, DHCP, NTP, etc) are provided to the network by the pfSense firewall (while it is not as powerful as the Mikrotik gear I have it is much more functional and flexible). I have defined the VLANs on the firewall and RB-4011 and have an existing working trunk between them with existing devices using access ports and another hAP AC Lite configured via another trunk from the RB-4011, I want to use the 2nd trunk on the pfSense firewall which currently goes to a Netgear switch and move this to the RB-5009. So basically need to configure a trunk port and VLANs on the RB-5009.
If you refer to my original post about the RB-4011 the RB-5009 will be the SWITCH (192.168.5.250) in the diagram.
kk
I would also use the unused ether8 as ether8-emergaccess.
Give it an IP of 192.168.66.2 network 192.168.66.0
take ether8 off the bridge.
Ensure you add it to the management interface as a member.
Step 1:
You have to define ALL the vlans on the RB5009, you only have defined vlan50 ???
In other words they all need to be identified and with interface being the bridge.
Step 2:
Since its not routing, you dont need any firewall rules
Step3:
Ensure the router has an IP address on the management vlan subnet.
Step4:
Ensure the router has an IP route to the gateway IP of the management vlan
dest address=0.0.0.0/0 gateway =192.168.5.1
Step5: the only interface you need to define (not wan, not lan)
add name=MGMT
/interface list members
add interface=vlan50 list=MGMT
add interface=ether8-emergaccess list=MGMT
Step6:
Setup the bridge ports
/interface bridge ports
EACH port/WLAN that is attached to the bridge gets ONE line
EACH port/WLAN is either
associated as a TRUNK port (carrying one or more vlans as tagged packets both outgoing and incoming to the port - aka to smart managed devices)
OR
associated as an access port (carrying one vlan which will be untagged coming out of the port and tagged when coming back into the port - aka to dumb devices PCs)
OR
(there can also be hyrid ports if requried (multiple tagged vlans and one untagged vlan).
/interface bridge vlas
EACH VLAN ID gets one line ( an exception is two or more vlan-ids are identical in their tagging)
Bridge is tagged as well as all trunk ports
All access ports are automatically dynamically untagged due to the associated pvid setting for access ports on the bridge port settings.
However I also manually untagg them on the bridge vlan settings so that I can quickly understand a config.
In summary, the MT Router acting solely as a bridge is quite a simple clean setup.
Give it a go and then provide the config as per
Step 7
Setup the bridge vlans
Step 8
Turn on vlan filtering on bridge.
Thanks anav, your suggestion to add ether8 as a management port was the kick in my head I needed to be able to get the configuration below. Thanks very much for your assistance.
# Topic:		RB-5009 Initial Setup and VLAN configuration Post 2
# Web:			http://forum.mikrotik.com/t/rb-5009-initial-setup-and-vlan-configuration/153441/1
# Date:			2021-11-18
# Thanks:		Mikrotik, sid5632, anav
# VLAN Overview
# Port Overview
# ether1 = Trunk port to SG-2100 Port 2 (All VLANs)
# ether2 = Windows device (VLAN100)
# ether3 = Linux device (VLAN50)
# ether4 = Linux device (VLAN100)
# ether5 = Unused
# ether6 = Unused
# ether7 = Unused
# ether8 = Management access to RB-5009 (192.168.5.99)
# sfp-sfpplus1 = Unused (No WAN)
# Router Access
# RB-5009_Bridge = 192.168.5.250/24 (VLAN aware)
# ether8 = 192.168.5.99/24
# Interfaces
add admin-mac=00:00:00:00:00:00 auto-mac=no name=RB-5009_Bridge vlan-filtering=\
    yes
set [ find default-name=ether8 ] name=Eth8_Management
/interface vlan
add comment="WAN port" name=WAN
add comment="All Server_VLAN50 devices" name=Server_VLAN50_Devices
add comment="All Back_VLAN100 devices" name=Back_VLAN100_Devices
add comment="All VLAN devices" name=VLAN_Devices
add comment="All management devices" name=Management_Devices
add comment="Default_WAN" interface=sfp-sfpplus1 list=WAN
add comment="Default_Bridge" interface=RB-5009_Bridge list=LAN
add comment="VLAN_Trunk" interface=Eth1_SG-2100_Port2 list=LAN
add interface=Eth5_UNUSED list=LAN
add interface=Eth6_UNUSED list=LAN
add interface=Eth7_UNUSED list=LAN
add comment="Management_Port" interface=Eth8_Management list=LAN
add interface=RB-5009_Bridge list=Server_VLAN50_Devices
add interface=Eth1_SG-2100_Port2 list=Server_VLAN50_Devices
add interface=Eth3_Backberry list=Server_VLAN50_Devices
add interface=Eth2_Hammerstein list=Back_VLAN100_Devices
add interface=Eth4_Kodi list=Back_VLAN100_Devices
# Bridge
add bridge=RB-5009_Bridge frame-types=admit-only-vlan-tagged ingress-filtering=\
add bridge=RB-5009_Bridge frame-types=admit-only-untagged-and-priority-tagged \
    ingress-filtering=yes interface=Eth2_Hammerstein pvid=100
    ingress-filtering=yes interface=Eth3_Backberry pvid=50
    ingress-filtering=yes interface=Eth4_Kodi pvid=100
# port with pvid added to untagged group which might cause problems, consider addi
 g a seperate VLAN entry
add bridge=RB-5009_Bridge tagged=RB-5009_Bridge,Eth1_SG-2100_Port2 vlan-ids=\
    1,50,100,200,300,400,500,600
# TCP/IP
set discover-interface-list=all
add address=192.168.5.99/24 interface=Eth8_Management network=192.168.5.0
/ip cloud
set update-time=no
add action=accept chain=input comment="defconf: accept ICMP" disabled=yes \
    protocol=icmp
    "defconf: accept to local loopback (for CAPsMAN)" disabled=yes \
    connection-state=new disabled=yes in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes \
add disabled=no dst-address=0.0.0.0/0 gateway=192.168.10.1 routing-table=main \
/ip ssh
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    ipsec-ah
    ipsec-esp
    !LAN
# System
/system clock
/system identity
set name=RB-5009
/system ntp client
set enabled=yes
set channel=testing
/tool mac-server
set allowed-interface-list=all
This is working for me and I have devices connected to the RB-5009 utilising VLAN 100 and 50 just fine, everything working as expected.
