rb1000 hotspot
Having a strange problem occur from time to time on the rb1000, version is 3.16
every now and then users instead of being redirected to the hotspot page we designed, they get the default mikrotik page.
wondering if this is a known issue on this particular board, and if there is a fix for it.
if anyone needs a suppout i’ll post that.
thanks in advance.
the only possible fix is newer versions, like 3.22 =)
Well, is this a known issue? Has anyone else experienced it? My routerboard 1000u in the system resources in winbox says there’s 4 bad blocks, is that normal? It makes me nervous to say the least… unless of course they’re marked that way for a reason.
I didn’t see any changes on the hotspot in the 3.22 upgrade so I wasn’t going to upgrade so quick… don’t want to introduce new bugs into an already buggy system.
Thanks for the reply though!
Cheers.
