RB1000 U rebooting
Hi guys,
i have one rb1000 and i have to reboot, but wen she come back, my routerboard start rebooting along, i try reinstall the router OS over netinstall bunt dont work. i connect by serial cabe and y change the boot preferences for ethernet and still dont get the install server and this is the message i try in 2 diferentes network cards
firt card message
Welcome to MikroTik Router Software remote installation
Press Ctrl-Alt-Delete to abort
mac-address: 00:0C:42:20:7E:48
mac-address: 00:0C:42:20:7E:49
mac-address: 00:0C:42:20:7E:4A
mac-address: 00:0C:42:20:7E:4B
software-id: 1UW9-TVG7 key:
bsVdVwFOLLS6Whxl4msd001iyVASYXd/xLrW95ASFSrKqpStjv/UQd6muqnfhNKHbe34JambTpsqAdly
xGOfsD==
Waiting for installation server…
and freeze, and not install the software and not show on net install
second card message:
RouterBOOT booter 2.20
RouterBoard 1000
CPU frequency: 1333 MHz
Memory size: 512 MB
Press any key within 2 seconds to enter setup..
kernel not found
trying bootp protocol… OK
Got IP address: 192.168.1.1
failed to resolve mac address
kernel loading failed
and now i dont now wat to do!
Please someone cant help my..
i need this routerboard
thanks to all
someone fron mikrotik cant say wy this happing please
I would send this to support@mikrotik.com..
I did give you the most common reasons though for it.
this is the test memory fron my routerboard 1000
This may take some time, ESC aborts testing
Cached memory
Fill memory with addresses:
Filling memory… done
Testing memory… done
Random data test:
Invert random data test:
Waiting 00 OK
Fill memory with zeroes:
Fill memory with ones:
Fill memory with x55555555:
Fill memory with xaaaaaaaa:
Uncached memory
Random data test:
Waiting 00 OK
