Why is this not on ROUTERBOARD.COM ?? I had to read it at a vendor site.
Routerboard - RB1100AHx2
This device is our best performance 1U rackmount Gigabit Ethernet router.
With a dual core CPU, it can reach up to a million packets per second.
It has thirteen individual gigabit Ethernet ports, two 5-port switch groups, and
includes Ethernet bypass capability. 2GB of SODIMM RAM are included, there is
one microSD card slot, a beeper and a serial port.
The RB1100AH comes preinstalled in a 1U aluminium rackmount case, assembled and ready to deploy.
CPU - PowerPC P2020 dual core 1066MHz network CPU with IPsec accelerator Memory - SODIMM DDR Slot, 2GB installed (RouterOS will use only up to 1.5GB) Boot loader - RouterBOOT, 1Mbit Flash chip Data storage - Onboard NAND memory chip, one microSD card slot Ethernet - Thirteen 10/100/1000 Mbit/s Gigabit Ethernet with Auto-MDI/X Ethernet - Includes switch to enable Ethernet bypass mode in two ports miniPCI none Serial Port - One DB9 RS232C asynchronous serial port Extras - Reset switch, beeper, voltage and temperature sensors Power Options - Built-in power supply (IEC C14 standard connector 110/220V), PoE (12- 24V on port 13) Fan - Built in fans, and Fan headers Dimensions - 1U case: 44 x 176 x 442 mm, 1275g. Board only: 365g Operating System - MikroTik RouterOS, Level 6 license
We normally pre-announce new products to distributors first, only later put the product on our webpage, because Distributors usually need to know this first, or they will get even angrier than you
