I’ve 1 rb112 which cannot start. when I try using Mac telnet to the RB it done but after I enter username & password then directly disconected with " Timed Out and dissapear.
does anyone has any experience with this situation? how to solved this problem?
I’ve try using Mikrotik Neighbour Viewer , but the application cant detect my RB.
if, all ways you did try, cann't connect too, only last way with physical 'serial cable' and running with 'HyperTerminal' application from windows.
i hope you will success to login to your Router.
