RB133C and/or UTP causing FM radio interference?
I have a client radio on a bottle store servinc 2 shops in a shopping centre. Now suddenly the guy says that my stuff is causing his FM radio stations not to work or with a lot of noise. The CPE is right above his shop and a 90m UTP is running across his roof. He is convinced that it is my stuff that intermittently causing the problems.
Switching the CPE off caused little difference but it seems that once it is associated, it cause more interference.
Is it possible that either the RB or WiFi or UTP is causing it?
Ekkas
It’s probably the ethernet cabling. Either use shielded cable or turn down the ethernet to a fixed 10mbps. 100mbps ethernet does cause interference with lots of radio stuff.
Thanks, I’ll give it a try. Ordered some shielded UTP today…
