RB2011 Announcement ?
Maybe turn off the browser/proxy cache, as the info is both at distributors, and also on routerboard.com for a while already!
http://routerboard.com/RB2011L-IN
Seemed to have missed that :open_mouth:
Sorry Normis - and thnx.
Do you plan to release all RB2011 with same CPU/RAM configuration or there will be differences between models?
Just asking because RB2011L-IN is exactly what I’m looking for, but if you plan to release a more powerful version I would be happy to pay more for it :sunglasses:
all RB2011 will have the same next-gen Atheros CPU
Will throughput/pps tables be posted to the product page?
what is MTU on Gigabit and FastEthernet ports ?
Max L2MTU on RB2011 series:
ether1-ether5: 4047; ether6-ether10: 2028
Thanks!
How about AR9344? Does it support ipsec acceleration? All RB2011 models will be same CPU?
Same CPU, no acceleration.
:frowning: But I love it.
This is going to be a super low cost product. Acceleration is only in our high-end devices.
My wish is you guys make RouterBoard chassis, that can integrate/merge routers for to improve performance. Like Cisco stacking or Line card option. For example (only my vision):
I have 5Unit RBChassis with RB2011(rackmount). It is very good for my office environment. Once we need to connect to other office through IPSec, so we will install RB1100AHx2 for 400Mbps IPSec only. 2 months later boss says need to filter total 1Gbps traffic using L7 and content filter. So I`ll install second RB1100AHx2 etc…
Of course need to upgrade RouterOS, that can manage many routerboards by one management. If I configured router as IPSEC role. It is only able to used for IPSec. If I configure router as PPPoE server role, It is only able to run PPP processes. It means we can manage 3 routerboard by one RouterOS.
Sorry for my bad english. :slight_smile:
When can we see rb2011 with sfp connection on resellers list?
now it’s only rb2011L :frowning:
wait a second, no RFC throughput test results ?!
will be posted in a few days
RB2011L-RM is 1U and how much inches?
Can we have a normal USB port so we can plug in WiMAX USB dongles and 3g USB dongles? What about USB ADSL Modems ? Thanks.
This is a microUSB port so that you can use your standart phone charger cable to plug the router into your PC and configure it directly over USB (something like a replacement for serial port). There are also some other exciting features planned for this port.
You know a usb WiMAX dongle which works with MT?
