Hi guys,
I have just installed a RB2011UAS-RM for a customer and discovered a problem with the LAN speed negotiation.
I connected LAN port 3 on the RB to a BT FTCC modem (ECI V-2FUb/I Rev.B) and discovered it negotiated at 10 Mbps. First thought was of course bad cable. Having replaced the cable the same problem exists. I started fiddling around with switching the auto negotiation off and full duplex. Forcing 100 or 1000 Mbps causes the link to be lost.
I then moved over to port 6 on the RB - same problem with auto negotiate. I think I may have been able to force 100 Mbps but only half duplex (struggling to remember exactly what I tried).
Next I tested the BT FTTC modem connected to a laptop using the same cable - full 1000 Mbps
Then I connected the RB to the laptop using the same cable - full 1000 Mbps on port 3 and 100 Mbps on port 6.
Is this some kind of bug in the RB hardware or incompatibility between devices?
The BT modem is locked and as such not a single setting can be changed on that device.
I’ve had to put a standard 10/100 switch between the two devices just to get above 10 Mbps.
Tried ROS 5.24 and v6.0rc11 with no change.
Any suggestions?
Cheers
Henry
Update 24/02/2013: Found another Mikrotik user from the UK with the same problem and similar equipment. The thread is here (with no positive outcome)
Someone with a similar port speed issue here (with no positive outcome)
And another thread with port speed problems here (with no positive outcome)
And finally some mention of it here here
