Hi, is it possible to turn the RB2011UiAS-2HnD-IN LCD touchscreen content upside down?
I must to hang the router with the ethernet ports up and the antennas down so I need to turn the LCD content upside down.
Thanks in advance
M
Thanks in advance
M
I dont think this is possible. But, chances are you won’t use it any way.
You can remove LCD and rotate
By the way, MikroTik, why not to add this, really useful on some installs, feature?
Just some days ago wished I could rotate LCD interface.
We will add such option to one of the next RouterOS versions. Thanks for the suggestion
Whilst we’re proposing changes to the LCD, could we also add the ability to add custom image or text?
I will see what I can do
Being able to put some arbitrary text on the LCD via scripting would be great!
