RB260/CSS106 SNMP Access to SFP TX/RX Power?
Hello everyone,
I have set up a CRS106-1C-5S as a primary Switch, connecting multiple RB260 (v1 and v2 aka CSS106) and an RB2011 via singlemode Fiber.
While everything runs fine, i wanted to monitor the fiber connections, especially the TX and RX Power Levels on each side. Getting this Data via SNMP was no Problem on the CRS and RB2011, but the CSS106 doesnt want to tell much. I only got Temperature and Supply Voltage/TX Current, but no Optcal Power. An older RB260 (first version, pre-CSS106) doesnt like to talk much at all (only Ethernet Stats)
Is there any other way to get this Information without using curl/wget and scraping the Webadmin page? All SFP in use have DDM and the Data is available on the Webadmin.
Thank you and good night!
