I’m new to Mikrotik and still learning from where I can found a solution for a problem.
Currently, I faced with the following situation.
My IPS gives me two IPs: IP1 and IP2 (ether1 and ether5), coming from the GPON router
I’ve built 2 bridges bridge 1 - ether 2, 3, 4, 6, 7, 8, 10) for IP1 and bridge2 - ether 9 for IP2.
Whatever I’m trying to do, everytime I end with only one working IP. My last try was that the bridge 1 uses IP1, but bridge 2 does not have internet access at all (event with NAT).
I’m I doing something wrong, or the things are not supposed to work like this.
There is my last configuration with one working bridge.
add admin-mac=48:8F:5A:6F:42:07 auto-mac=no comment=defconf name=bridge
add name=bridge1
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=WAN2
add name=default-dhcp ranges=192.168.88.2-192.168.88.128
add name=pool1 ranges=192.168.88.129-192.168.88.254
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add address-pool=pool1 disabled=no interface=bridge1 name=server1
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge1 comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp1
add interface=ether1 list=WAN
add interface=ether5 list=WAN2
add address=192.168.88.1/25 comment=defconf interface=bridge network=\
192.168.88.0
add address=192.168.99.1/24 disabled=yes interface=bridge1 network=192.168.99.0
add address=192.168.88.1/25 interface=bridge1 network=192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
add disabled=no interface=ether5
add address=192.168.88.0/24 comment=defconf dns-server=8.8.8.8 gateway=\
192.168.88.1
set allow-remote-requests=yes
/ip dns static
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=accept chain=forward in-interface=bridge1
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
out,none log=yes log-prefix=ppp out-interface-list=WAN2
add distance=1 gateway="ether5,[ISP_GATEWAY_HERE]@(unknown)" routing-mark=second-ip
/ip route vrf
add interfaces=ether1,bridge routing-mark=main-ip
add interfaces=ether5,bridge1 routing-mark=second-ip
NOTE VRF was used after I read for some possible solutions regarding my problem, but I’m not 100% sure that I need it, because I’m not so familiar with it.
Thanks.
