RB3011UiAS-RM
Hi, if safe why the log complains about impropper shutdown? Maybe the message needs to be changed.
Thank you very much for extended explanations. Now I understand.
On paper sounds brilliant. Execution not so great though and MT support don’t seem to be able to answer this;
http://forum.mikrotik.com/t/weird-routing-loop-in-logs-but-there-isnt-one/95280/1
Hi!
Sorry for my bad English.
Is this hardware is good and stable? The 2x1,4GHz ARM CPU sounds good but it is the first ARM based hardware router on the Mikrotik repertoire as I know.
Can somebody write his experience with this device?
Thanks!
It has some problems with mysterious false-positive loop detection, but other than that it’s good.
Thanks your answer!
What is the false-positive loop detection problem exactly? I never heard about this problem.
There’s a separate topic about that issue: http://forum.mikrotik.com/t/weird-routing-loop-in-logs-but-there-isnt-one/95280/1
Thank you I read this topic. I think even I’m waiting a few months to purchase… This is a new architecture. The Mikrotik still have to work on it.
I am interested in using the 3011 device. Would be interesting for me too when the bug is fixed. Thanks
Anyone tested OVPN throughput when using aes-256?
Thanks!
I’ve just got my RB3011, and it seems that USB port isn’t working. Modem starts to blink, but no LTE interface appears. USB flash drives are not visible too. Is it a hardware problem? Should I replace the device?
With the latest software update 6.36rc28 my RB3011 doesn’t see any usb devices. With current version it works fine.
I can confirm. I tried with several USB device and does not work on 6.36rc28. All works fine in 6.35.4
We replicated problem and we will fix this issue with RB3011 and usb.
have anybody tested RB3011UiAS-RM with shared drive connected on USB 3.0 port for SMB or Widows share performance ?
Which speed are you getting ?
I only had an USB2 HDD, got 30mb/s on SMB.
did the encryption hw acceleration ever get turned on for this model?
No this requires a kernel newer than the 3.3 that RouterOS v6 uses.
Your best bet is to use a CCR1009, RB1100AHx4 or RB750Gr3
what about flapping 6-10 ports of 3011?
http://forum.mikrotik.com/t/rb3011-interface-link-problems/95444/1
http://forum.mikrotik.com/t/rb3011-packet-loss-on-switch2-group/106872/1
Is it gonna be fixed or is it gonna stay this way forever?
IPsec accelerator (HW acceleration) RB3011UiAS-RM ???
Когда, сколько ждать?
When, how long to wait?
