rb333 mt3.0rc4
'ello.
poor old me is having problems with rb333 mith mt 3.0rc4 (preinstalled) and 350mW mt wifi card set as apbridge for 30clients. All clients have static ip.
Signals are ok -54 to -70 but on random clients i get last ip 0.0.0.0 and those clients can not even ping my ap. Their device is shown in registration list.
  1. If those clients restart their wifi device, ip is shown again and all works fine for random number of minutes/hours.
  2. If I disable and enable again apbridge interface all works fine fine for random number of minutes/hours.
    When some clients do not work others work fine.
Should I call Molder or SWAT for help :slight_smile:
does that update option work? That mt is high up on the comm tower.
if i understand it right new mt should be installed on pc or rb and connected to system you want to upgrade. and then start upgrade option from ip of that pc/rb???
tnx mate.
will report result soon
huh those were loooooooongest 5 minutes.
all is well. uprgrade was succesfull. :slight_smile:
Hope that original problem will be gone now.
tnx
