Just replaced my gateway MT with a rb333, set it up with a public IP on eth 1 and a r52 in a point to point link into our network, running RIP routing, defult route out, masquerade, firewall port 22, 23, 80 on the wan side, honestly nothing special or unique.
have compared it with the old unit (2.9.46) and everything looks the same.
first noticed it when skype wasn’t working, then people started calling saying there online banking wasn’t working.
The issue is not related to RB333, I have very similar configuration, when RB333 is main gateway to Internet. It is working great.
3.0rc4 has issues with distributing default route over RIP, it is fixed at 3.0rc5.
You may try to set static routing, then SSL pages, skype should work. Note, that skype is not easy service to block, if it is not working, then most likely problems are with entire Internet connection.
Probably, I was not too precise in the previous post.
As you do not mention any details about “Old router”, probably it is not 3.0rc4, but 2.9.46 that’s why it does not have this problem with RIP (there is issue with distributing default route). As I said you may just change to static routing, then it should work.
3.0rc5 is not released yet, you may subscribe to notification at the downloag page, you will get the mail, when new version will be released. 3.0rc5 will be released very soon.
You may look at RIP routes and replicate them with static entries.
As route entry contain two parts dst-address and gateway, dst-address is the address of the destination network, gateway address that is used to route packets over this IP.
E.g.
Router1(192.168.0.1) — (192.168.0.2) Router2 (192.168.1.1);
Router1 should contain the particular entry to reach Router2 local network,
ip route add gateway=192.168.0.2 dst-address=192.168.1.0/24
Default gateway should be set on Router2 to, as 192.168.0.1.
router1 (gateway rb333)
wan IP x.x.x.x–wlan IP 10.10.120.1/30 AS 0.0.0.0/0 GW x.x.x.n
where x.x.x.x is my public address and x.x.x.n is the upstream gateway
router2 (2.9.46 running RIP)
wlan IP 10.10.120.2/30 ip route add gateway=x.x.x.n dst-address=10.10.120.1/30
right i get it, so your essentially telling router 1 how to find the other side of router 2.
i assume if i have mor than one interface on router 2 i will need to add a second route to router 1 telling it how to find this subnet also.
not sure how to test it, has not appeared to have made any difference to skype or banking. all other browsing continues to work fine
