RB333 vs RB433
I need to buy a new RB for my WIPS, rb433 is the replacement for the rb333, but is really better? rb333 had a second co processor specially for network usage. Rb433 only has 1 cpu, does it really work better? cause rb433 is cheaper…
Which RB will work better with 2 Ubiquiti XR2 for a WISP scenario and 40 clients per card?
Thank you.
Check out the May throughput comparison, the RB433 is faster. http://routerboard.com/pdf/tests_may_2008mbps.pdf
I’d like to know if the RB433AH or RB600 is faster.
RB600 can be upgraded…
RB433AH is faster, but RB600 supports more interfaces, 48V and has gigabit ports …
thank you so much, Ill try to wait for the RB433AH arrive to argentina.
