RB4011 PoE AP
Hey guys, I have recently bought RB4011 and Netgear WAX214 AP.
I would like to conect lan cable from PoE out ethernet port to PoE in port on AP, but it does not turn on when I do that. I have tried 3 different cat cables.
Do I have to turn this feature on or do something else?
Thank you!
RB4011 only support Passive PoE (both -in and -out). Datasheet for your AX214 does not provide any information on what types of PoE it accepts, so I assume it is 802.3af/at only. Which means they are not compatible and you cannot power AX214 using RB4011.
Is 802.3at 30W (PoE+)
