Thanks to a good friend at work we now have an ASUS wifi router with WiFi6 on it to join the network. This is mainly because people were complaining about the wifi stability issues regarding Apple devices and Mikrotik (seems to be a bad combo), and according to this friend they never have issues with this asus router, so there we are.
Either way, at this time we run a separate DNS server for the network (one with piHole and unbound, which we are very happy with),
DHCP is done by the RB4011iGS+5HacQ2HnD, which I would probably also like to keep that way. This RB4011 also is connected to the WAN (an internet modem) right now, but I could change that to be done by the ASUS router (it does have a much faster CPU, and probably higher throughput than the RB4011, but I haven’t tested that).
This ASUS RT-AX89X has a WAN port, but since it’s mostly to do with its wifi abilities, I’m not sure how to set up the network now.
All ports, including the SFP+ port, of the RB4011 are in use, and 4 of its 1G LAN ports are set up as bound ports (2Gb) to two local servers.
Knowing all this, how would you people implement this ASUS into this network? I could use it as a mere switch and AP, but I think I’ll also prefer to have it do NAT and so use ASUS’ WAN port, take over that role from the RB4011.
Would then having the RB4011 do DHCP for the entire network make it slow down anything?
And how would I best connect the two routers? I could create a bonding link between the two (2Gb), so that at least it’s faster than just one LAN to LAN port. The ASUS offers 802.3ad on its first two LAN-ports. Just found out I can also use the 10G SFP+ port on the ASUS as a LAN port, so that way I can use a DAC SFP+ cable between the RB4011 and the RX89X, sweet!
Either way, I will switch off the WiFi on the RB4011, and use the WiFi6 ability on the AX89X, as a minimum.
Just curious on how any of you would set this up, and why.
(Firewalling to/from the interwebs is not much of an issue, since the internet modem WAN side already does CGNAT, so I’m basically two NATs away from the internet, at all times. I can only run public servers/sevices using ssh port-links through an external server anyway. So security is not much of a worry here, as long as we have no idiots on the network clicking links and/or running stupid IoT devices as botnets etc. but as this is an IT-company, they’ve never had such issues.)
