RB4011 vlan bridge
Hello, I have an RB4011 with running the ethernet ports in bridge mode, and one of the ports (eth5) is connected with my UnRaid server. I have setup vlan interface vlan22 on RB4011 and there are two interfaces (br0 and br0.22) in my UnRaid server, the issue is my UnRaid server is able to get IP on br0 but failed on br0.22. I have tried to capture the traffic on RB4011 and able to see my UnRaid server is sending DHCP traffic but no response from my RB4011. I believe there is something wrong on my bridge vlan configuration.
/ Interfaces
Name: Vlan22, VLAN ID: 22, Interface: Bridge1
/ Bridge
Name: Bridge1, Vlan Filtering: Yes, PVID: 1
/Bridge Ports
Interface eth5, Bridge: Bridge1, PVID: 1, Frame Types: admin all
/Bridge VLANs
(Default) Bridge: Bridge1, VLAN IDs: 1, current Untagged: Bridge1, eth3, eth4, eth5, eth7, eth8
Bridge: Bridge1, VLAN IDs: 22, Tagged: Bridge1, eth5
Something like this:
add admin-mac=[fill in a MAC address of one of the ether ports] auto-mac=no ingress-filtering=no name=Bridge1 protocol-mode=none vlan-filtering=yes
/interface vlan
add interface=Bridge1 name=Vlan22 vlan-id=22
add bridge=Bridge1 frame-types=admit-only-untagged-and-priority-tagged interface=eth5 pvid=22
/interface bridge vlan
add bridge=Bridge1 tagged=Bridge1 Untagged: eth5 vlan-ids=22
If you start using VLAN’s, don’t “use” VLAN 1 (as it is there already).
And also read this topic carefully: http://forum.mikrotik.com/t/using-routeros-to-vlan-your-network/126489/1
Thanks. I tried to follow your configuration but my UnRaid server br0 will lose the connection after applying it. Looked at the link and it seems I need to set hybrid port on eth5.
My bridge interface is using 192.168.10.0/24 (Default pvid 1 after enabling vlan filtering)
VLAN22 - 192.168.22.0/24
My UnRaid server is:
Br0 (normal ethernet interface): DHCP
BR0.22 (vlan interface): DHCP
My current configuration:
add admin-mac=[MAC address] auto-mac=no ingress-filtering=no name=Bridge1 vlan-filtering=yes
/interface vlan
add interface=Bridge1 name="vlan22" vlan-id=22
add bridge=Bridge1 comment=defconf ingress-filtering=no interface="eth2"
add bridge=Bridge1 comment=defconf ingress-filtering=no interface="eth3"
add bridge=Bridge1 comment=defconf ingress-filtering=no interface="eth4"
add bridge=Bridge1 comment=defconf ingress-filtering=no interface="eth5 - UnRaid"
add bridge=Bridge1 comment=defconf ingress-filtering=no interface="eth6" pvid=22
add bridge=Bridge1 comment=defconf ingress-filtering=no interface="eth7"
add bridge=Bridge1 comment=defconf ingress-filtering=no interface="eth8"
add bridge=Bridge1 comment=vlan22 tagged="Bridge1,eth5 - UnRaid" vlan-ids=22
add address-pool=Bridge1 interface=Bridge1 lease-time=30m name=Bridge1
add address-pool=vlan22 interface="vlan22" lease-time=30m name=vlan22
add name=Bridge1 ranges=192.168.10.50-192.168.10.70
add name=vlan22 ranges=192.168.22.50-192.168.22.70
add address=192.168.10.1/24 interface=Bridge1 network=192.168.10.0
add address=192.168.22.1/24 interface=vlan22 network=192.168.22.0
If you are interested in using all vlans for data (and not vlan1) I am interested in helping… in other words, bridge does no DHCP…
old
add bridge=Bridge1 comment=vlan22 tagged=“Bridge1,eth5 - UnRaid” vlan-ids=22
replace with
add bridge=Bridge1 comment=vlan22 tagged=Bridge1,“eth5 - UnRaid” vlan-ids=22
The difference is the placement of the double quotes. You don’t need Bridge1 quoted (although it can be) but the “eth5 - Unraid” has to be quoted because it has spaces in the name. The comma separating interfaces should not be inside the quotes.
Please posts output of /interface bridge vlan print and /interface bridge vlan print detail both before and after the change.
