Hello guys,
I have old 433 and forgotten password. I tried this:
1- unplug all cables
2- press and hold RESET
3- plug in power
4- keep holding RESET for more than 1 minute
5- leave it for few minutes
6- reboot
this time result was both diods off, no flashing, during reseting and after.
Afte waiting long time and few reboots I could see diods flashig again.So I tried login with WinBox.
IP was 192.168.44.123 (is this default/factory???)
Tried this logins:
admin/(blank)
admin/admin
(blank)/(blank)
Always wrong username or password.
Then I googled and found 30/30/30 reset.
1-unplug cables
2-press reset, hold it and plug in power cable
3-hold 30sec. and unplug power
4-keep hoilding 30sec. and plug in power
5-keep holding 30sec. and then unplug cable.
During this last step, diods where flashing(unlike above). I was waiting few minutes to give it time to reset/reinstall, or whatever.
After few minutes, same problem with login and IP was same: 192.168.44.123
and what is that thing with diodes off? During resetting and after resetting, both diodes are off, not flashing. It takes few minutes, even if I reboot.
I just tried netinstall, but Etherboot didn’t work. Device doesn’t show up in Netinstall. Also again issue with diodes, they are both off. Now I have to leave device without power for few minutes to boot it with diodes flashing again.
After that it will boot correctly, bacause WinBox can see it.
Every time when I try reset button I have same issue with diodes. Is it broken? There were no problems with it, we only forgot password.
didn’t work. I was trying everything I googled.
On some website I found reset called 30/30/30 and this one must work for every mikrotik … except the one I am trying reset
But anyway, if I press reset, after while I should see diods flashing, right? But I don’t.
