l just bought RB433AH with 1wat radio and l’m planning to give out WiFi AP and cover 10km raidus.I’m completely at a loss as to the setup and all,The manual I downloaded from routerboard.com doesn’t really help. l need some help on how to config RB433Ah, l want to config RB433AH to run AP,setup Hotspot,DHCP Server. Below is the info my ISP gave me:
thanks for your help. hv config the wlan1,LAN and hotspot. (LAN use info supplied by my ISP). The hotspot give out ip by DHCP but the problem now is browsing. after configuring he browse for 2mins and stop. l ping my DNS timout. pls l need your help on what to do to allow my client browsing?
did you get the hotspot login page?
where did you ping your dns? , router?, client?
can you ping website from router ? from client ?
check route 0.0.0.0/0 → your gateway?
l ping dns from the route is timing out, l also ping the DNS from the client same problem. Also what could be the problem while the hotspot login page is not displaying too?
