I got 10Gbps internet from my ISP previous week and I’m having trouble getting more than 1Gbps from them. I updated to the newest ROS version: 7.11.2. Do you need to enable something to get more than 1Gbps on the 5009 Series or am I doing something wrong? Profiler shows CPU utilization ~50-30% on all cores when getting 800Mbps.
I’m currently running the most basic config:
# 2023-10-09 20:40:55 by RouterOS 7.11.2
add name=BR-LAN
set [ find default-name=ether1 ] advertise=2500M-full
add name=DHCP_LAN ranges=10.0.0.20-10.0.0.254
add address-pool=DHCP_LAN interface=BR-LAN lease-time=20m name=LAN
add bridge=BR-LAN interface=ether1
add bridge=BR-LAN interface=ether2
add bridge=BR-LAN interface=ether3
add bridge=BR-LAN interface=ether4
add bridge=BR-LAN interface=ether5
add bridge=BR-LAN interface=ether6
add bridge=BR-LAN interface=ether7
add bridge=BR-LAN interface=ether8
add address=10.0.0.1/24 interface=BR-LAN network=10.0.0.0
/ip dhcp-client
add interface=sfp-sfpplus1
add address=10.0.0.0/24 dns-server=1.1.1.1,8.8.8.8 gateway=10.0.0.1
add action=accept chain=input connection-state=established,related
add action=drop chain=input in-interface=sfp-sfpplus1
add action=masquerade chain=srcnat out-interface=sfp-sfpplus1
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
/ip service
set telnet disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=Europe/Ljubljana
/system note
set show-at-login=no
My sfp+ interface status(uplink port to ISP):
My ethernet1 status(port towards PC):
Can’t get more than ~800Mbps down:
