Hi all,
I wanted to share a reproducible data-corruption issue I tracked down on an RB5009UG+S+ running RouterOS 7.24.5, in case anyone else is seeing it.
Setup
Home LAN hosts --- CSS318 (SwOS) --- RB5009UG+S+ (7.24.5, arm64) === WireGuard (MTU 1420, IPv4 underlay) === CHR (version: 7.24.5) --- Proxmox Backup Server (VM on same host as CHR)
- Home hosts are 1500 MTU, on two VLANs routed by the RB5009
- MSS clamp (change-mss clamp-to-pmtu) on both ends for traffic in/out of the WG interface
- Default fasttrack rule present
Symptom
Large transfers from the home LAN to the datacenter over the RB5009's WireGuard tunnel randomly fail, roughly once every 5-8 GB:
- Proxmox backups fail with "backup write data failed: command error: protocol canceled". The PBS side logs "error reading a body from connection", and a packet capture shows PBS sending a TLS alert followed by an RST.
- scp of a 4 GB random file fails partway with "Connection reset by peer". The receiving sshd logs:
sshd-session: Corrupted MAC on input.
ssh_dispatch_run_fatal: Connection from user root x.x.x.x: message authentication code incorrect
So bytes are arriving changed, and TCP isn't catching it (TcpInCsumErrors on the receiver did not increase during the failing runs). My understanding is that after a successful WireGuard decrypt the inner packet is treated as checksum-verified, so corruption that happens before encryption gets through untouched until the TLS/SSH layer checks it.
Isolation (4 GB random file via scp, repeated 3-5x per path)
Path Result
Home host A -> RB5009 WG -> CHR -> PBS FAIL (MAC incorrect)
Home host B (different VLAN) -> RB5009 WG -> CHR -> PBS FAIL (MAC incorrect)
Home host -> RB5009 inter-VLAN routing -> home host PASS 3/3 (no tunnel)
Datacenter host -> PBS (no tunnel) PASS 3/3
Home host with its own WG peer -> CHR -> PBS PASS 3/3 (RB5009 only forwards outer UDP)
So only traffic that the RB5009 itself encrypts into WireGuard gets corrupted. Plain routing through the RB5009 is clean, and the CHR's decrypt/forwarding is clean with another peer.
Things that did NOT fix it
- Excluding WG traffic from fasttrack (accept established/related in/out the WG interface before the fasttrack rule)
- Upgrading RouterBOOT firmware from 7.16.2 to 7.24.5 to match RouterOS
- MTU/MSS: PMTUD works correctly on the path, and the MSS clamp makes no difference
What DID fix it
Downgrading the RB5009 to long-term 7.23.8. After the downgrade: 5/5 clean 4 GB passes (20 GB), where 7.24.5 failed within 1-2 passes every time.
Repro
dd if=/dev/urandom of=rand.bin bs=1M count=4096
for i in 1 2 3 4 5; do scp rand.bin user@<host-behind-tunnel>:/tmp/rand.bin || break; done
# then check the receiver: journalctl | grep -i 'authentication code incorrect'
Has anyone else seen this on 7.24.x, on the RB5009 or other arm64 boards? Happy to test fixes or provide more detail.
