Well, this is interesting…
Power - i think I can rule that out. I tried it with a new power supply, same issues. Tried it with ONLY the jack voltage and no 2pin power from DC, same issues. Tried it with ONLY the 2 pin DC voltage and no jack connector at all, same issues.
however, somehow, for some reason, it’s different/better???
Yesterday and today, it would stay up (no ethernet drops) for 7hrs, then 11hrs, then as much as 16hrs today. It would never go more than a few hours max before. When it does start to drop the ethernet and SFP it still drops all of them at exactly the same time, AND it does it several times every few seconds to every few minutes, it usually does this 5+ times every few seconds to every few minutes and then it’s good again for several hours - as much as 16hrs today??
Could it be some sort of networking related issue like a failing device causing the router to drop all connections? there’s zero details in the logs aside from interface down/up and then the multiple BFD/OSPF msgs as things reconnect back up.
I tried creating a firewall input rule to log packets heading to the router itself, but aside from legit traffic, there’s only a handful of TCP SYN packets, maybe 10 a minute at most, nothing that would really spike the CPU, etc.
I’ve been connected via winbox while the event happens, often it doesn’t even drop my winbox session at all. the voltage is solid, the cpu temp is at 45C right in normal range, the cpu is hovering around 20% no spikes, memory is flat at 800+ MB free, like there is literally zero indication of something “wrong” yet it still keeps happening!?? As I am typing this it’s flapping up/down like crazy, every min or so
I have not been stumped like this for a LONNNNNNG time. My only guess is that it’s some sort of traffic on the network hitting the router and causing it?? is that even possible?
