I tried to bring my RB5009 online tonight as my Internet router and it didn’t go well. It kept “freezing”. The WebUI would hang, pings to the internet through the box would fail, and then it would start passing packets again. Webfig was also hanging. I’ve looked at the logs and I see nothing particularly obvious. I do see this a lot:
jan/25 18:23:21 radvd,warning received Router Solicitation packet with invalid hoplimit=1
but that wouldn’t explain it stopping to pass ipv4 traffic.
My home topology is a Comcast modem connected to router connected to a root Cisco 3560CX. That 3560CX has two more 3560CXs hanging off of it. (Total of 3 switches.) The RB5009 is connected to the root 3560CX via 10G-SR optics:
interface TenGigabitEthernet1/0/1
description Mikrotik router
switchport trunk allowed vlan 200
switchport mode trunk
Pretty simple. I suppose this could have been a spanning tree fight in theory. But nothing in the logs would indicate as such. This is my config:
# jan/25/2023 19:36:59 by RouterOS 7.7
# software id = N8T2-QMED
# model = RB5009UG+S+
# serial number = EC1A0F20AF54
add frame-types=admit-only-vlan-tagged name=bridge1 vlan-filtering=yes
/interface vlan
add disabled=yes interface=bridge1 name=INSIDE vlan-id=200
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp_pool1 ranges=192.168.0.130-192.168.0.200
add address-pool=dhcp_pool1 interface=INSIDE lease-time=6h name=dhcp1
/system logging action
set 3 bsd-syslog=yes remote=192.168.0.69 syslog-facility=local7 \
syslog-severity=debug
add bridge=bridge1 frame-types=admit-only-vlan-tagged interface=\
sfp-sfpplus1
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged \
interface=ether2 pvid=200
interface=ether3 pvid=200
interface=ether4 pvid=200
interface=ether5 pvid=200
interface=ether6 pvid=200
interface=ether7 pvid=200
interface=ether8 pvid=200
add bridge=bridge1 interface=LAN pvid=200
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface bridge vlan
add bridge=bridge1 tagged=bridge1,sfp-sfpplus1 vlan-ids=200
add interface=INSIDE list=LAN
/interface ovpn-server server
set auth=sha1,md5
add address=192.168.0.1/24 interface=INSIDE network=192.168.0.0
/ip dhcp-client
add address=192.168.0.0/24 dns-server=8.8.8.8,1.1.1.1 gateway=\
192.168.0.1
set allow-remote-requests=yes servers=8.8.8.8,1.1.1.1
/ip dns static
established,related,untracked
add action=drop chain=input comment="defconf: drop invalid" \
connection-state=invalid
add action=accept chain=input comment="defconf: accept ICMP" protocol=\
icmp
"defconf: accept to local loopback (for CAPsMAN)" dst-address=\
127.0.0.1
"defconf: drop all not coming from LAN" in-interface-list=!LAN
"defconf: accept in ipsec policy" ipsec-policy=in,ipsec
"defconf: accept out ipsec policy" ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=\
"defconf: fasttrack" connection-state=established,related \
hw-offload=yes
"defconf: drop all from WAN not DSTNATed" connection-nat-state=\
!dstnat connection-state=new in-interface-list=WAN
/ip service
set ssh address=192.168.0.0/24
set www-ssl certificate=Webfig disabled=no
/ip upnp
set enabled=yes
/ipv6 firewall address-list
add address=::ffff:0.0.0.0/96 comment="defconf: ipv4-mapped" list=\
bad_ipv6
/ipv6 firewall filter
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
port=33434-33534 protocol=udp
"defconf: accept DHCPv6-Client prefix delegation." dst-port=546 \
protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=\
500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" \
protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" \
protocol=ipsec-esp
"defconf: accept all that matches ipsec policy" ipsec-policy=\
in,ipsec
"defconf: drop everything else not coming from LAN" \
"defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=\
icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" \
protocol=icmpv6
add action=accept chain=forward comment="defconf: accept HIP" protocol=\
139
add action=accept chain=forward comment="defconf: accept ipsec AH" \
protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" \
protocol=ipsec-esp
in,ipsec
/system clock
set time-zone-name=America/Los_Angeles
/system logging
add action=remote topics=debug
/system ntp client
set enabled=yes
/system ntp client servers
add address=time.cloudflare.com
/system routerboard settings
set cpu-frequency=1400MHz
/tool mac-server
/tool mac-server mac-winbox
Here’s what local logs showed:
00:23:58 system,info router rebooted
00:23:58 system,info,critical cpu not running at default frequency
00:23:58 interface,info INSIDE link up
00:24:07 system,error,critical login failure for user admin via local
00:24:08 bridge,info hardware offloading activated on bridge "bridge1" ports: ether2,ether4,ether5,ether3,ether6,ether8,sfp-sfpplus1,ether7
00:24:09 interface,info sfp-sfpplus1 link up (speed 10G, full duplex)
00:24:09 interface,info ether8 link up (speed 100M, full duplex)
00:24:11 dhcp,error temporary moving client sfp-sfpplus1 from slave to master port, update your config!!!
00:24:15 system,info,account user admin logged in via local
00:24:51 system,error,critical login failure for user admin from 192.168.0.42 via web
00:24:55 system,info,account user admin logged in from 192.168.0.42 via web
01:22:03 system,info dns changed by admin
01:22:05 system,info dns changed by admin
01:29:12 interface,info ether1 link up (speed 1G, full duplex)
01:30:43 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:30:43 radvd,warning source-address=fe80::d620:b0ff:fef1:195
01:30:50 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:30:50 radvd,warning source-address=fe80::d620:b0ff:fe80:ef0b
01:30:54 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:30:54 radvd,warning source-address=fe80::d620:b0ff:fe85:fc6f
01:30:56 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:30:56 radvd,warning source-address=fe80::5e5b:35ff:fe50:a9b
01:31:24 system,info device changed by admin
01:31:36 system,info dhcp client removed by admin
01:31:39 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:31:39 radvd,warning source-address=fe80::d620:b0ff:fef1:195
01:31:46 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:31:46 radvd,warning source-address=fe80::d620:b0ff:fe80:ef0b
01:31:50 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:31:50 radvd,warning source-address=fe80::d620:b0ff:fe85:fc6f
01:31:52 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:31:52 radvd,warning source-address=fe80::5e5b:35ff:fe50:a9b
01:32:35 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:32:35 radvd,warning source-address=fe80::d620:b0ff:fef1:195
01:32:42 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:32:42 radvd,warning source-address=fe80::d620:b0ff:fe80:ef0b
01:32:46 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:32:46 radvd,warning source-address=fe80::d620:b0ff:fe85:fc6f
01:32:48 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:32:48 radvd,warning source-address=fe80::5e5b:35ff:fe50:a9b
01:33:31 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:33:31 radvd,warning source-address=fe80::d620:b0ff:fef1:195
01:33:39 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:33:39 radvd,warning source-address=fe80::d620:b0ff:fe80:ef0b
01:33:42 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:33:42 radvd,warning source-address=fe80::d620:b0ff:fe85:fc6f
01:33:45 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:33:45 radvd,warning source-address=fe80::5e5b:35ff:fe50:a9b
01:34:28 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:34:28 radvd,warning source-address=fe80::d620:b0ff:fef1:195
01:34:37 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:34:37 radvd,warning source-address=fe80::d620:b0ff:fe80:ef0b
01:34:38 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:34:38 radvd,warning source-address=fe80::d620:b0ff:fe85:fc6f
01:34:39 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:34:39 radvd,warning source-address=fe80::5e5b:35ff:fe50:a9b
01:35:24 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:35:24 radvd,warning source-address=fe80::d620:b0ff:fef1:195
01:35:36 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:35:36 radvd,warning source-address=fe80::d620:b0ff:fe85:fc6f
01:35:36 radvd,warning source-address=fe80::d620:b0ff:fe80:ef0b
01:35:37 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:35:37 radvd,warning source-address=fe80::5e5b:35ff:fe50:a9b
01:36:22 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:36:22 radvd,warning source-address=fe80::d620:b0ff:fef1:195
01:36:33 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:36:33 radvd,warning source-address=fe80::d620:b0ff:fe85:fc6f
01:36:35 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:36:35 radvd,warning source-address=fe80::d620:b0ff:fe80:ef0b
01:36:36 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:36:36 radvd,warning source-address=fe80::5e5b:35ff:fe50:a9b
01:37:20 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:37:20 radvd,warning source-address=fe80::d620:b0ff:fef1:195
01:37:32 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:37:32 radvd,warning source-address=fe80::d620:b0ff:fe85:fc6f
01:37:36 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:37:36 radvd,warning source-address=fe80::5e5b:35ff:fe50:a9b
01:37:37 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:37:37 radvd,warning source-address=fe80::d620:b0ff:fe80:ef0b
01:37:41 interface,info ether1 link down
01:38:19 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:38:19 radvd,warning source-address=fe80::d620:b0ff:fef1:195
01:38:23 system,info dhcp network removed by admin
01:38:33 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:38:33 radvd,warning source-address=fe80::d620:b0ff:fe85:fc6f
01:38:38 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:38:38 radvd,warning source-address=fe80::5e5b:35ff:fe50:a9b
01:38:41 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:38:41 radvd,warning source-address=fe80::d620:b0ff:fe80:ef0b
01:38:48 interface,info ether1 link up (speed 1G, full duplex)
01:39:08 interface,info ether1 link down
01:39:09 system,info dhcp network added by admin
01:39:11 system,info dhcp network changed by admin
01:39:14 interface,info ether1 link up (speed 1G, full duplex)
01:39:19 system,info DHCP server setting changed by admin
01:39:20 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:39:20 radvd,warning source-address=fe80::d620:b0ff:fef1:195
01:39:36 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:39:36 radvd,warning source-address=fe80::d620:b0ff:fe85:fc6f
01:39:43 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:39:43 radvd,warning source-address=fe80::5e5b:35ff:fe50:a9b
01:39:47 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:39:47 radvd,warning source-address=fe80::d620:b0ff:fe80:ef0b
01:39:52 system,info pool dhcp_pool1 added by admin
01:39:52 system,info dhcp network changed by admin
01:39:52 system,info dhcp server dhcp1 added by admin
01:40:07 system,info address changed by admin
01:40:07 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:40:07 radvd,warning source-address=fe80::d620:b0ff:fef1:195
01:40:17 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:40:17 radvd,warning source-address=fe80::d620:b0ff:fef1:195
01:40:21 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:40:21 radvd,warning source-address=fe80::5e5b:35ff:fe50:a9b
01:40:22 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:40:22 radvd,warning source-address=fe80::d620:b0ff:fe80:ef0b
01:40:22 radvd,warning source-address=fe80::d620:b0ff:fe85:fc6f
01:40:27 system,error,critical login failure for user admin from 192.168.0.42 via web
01:40:30 radvd,warning received Router Solicitation packet with invalid hoplimit=1
01:40:30 radvd,warning source-address=fe80::d620:b0ff:fef1:195
01:40:31 dhcp,info dhcp1 assigned 192.168.0.199 for A4:06:E9:AB:2A:28 RingHpCam-28
01:40:35 system,info,account ion packet with invalid hoplimit=1
jan/25 17:51:11 radvd,warning source-address=fe80::5e5b:35ff:fe50:a9b
jan/25 17:51:12 dhcp,info dhcp1 deassigned 192.168.0.165 for 30:8C:FB:F7:95:11
jan/25 17:51:12 dhcp,info dhcp1 assigned 192.168.0.165 for 30:8C:FB:F7:95:11
jan/25 17:51:13 radvd,warning received Router Solicitation packet with invalid hoplimit=1
jan/25 17:51:13 radvd,warning source-address=fe80::5e5b:35ff:fe50:a9b
jan/25 17:51:16 radvd,warning received Router Solicitation packet with invalid hoplimit=1
jan/25 17:51:16 radvd,warning source-address=fe80::5e5b:35ff:fe50:a9b
jan/25 17:51:58 dhcp,info dhcp1 deassigned 192.168.0.165 for 30:8C:FB:F7:95:11
jan/25 17:51:58 dhcp,info dhcp1 assigned 192.168.0.165 for 30:8C:FB:F7:95:11
jan/25 17:51:58 dhcp,info dhcp1 deassigned 192.168.0.166 for 18:B4:30:8B:50:06 Nest-5006
jan/25 17:51:59 radvd,warning received Router Solicitation packet with invalid hoplimit=1
jan/25 17:51:59 radvd,warning source-address=fe80::d620:b0ff:fe80:ef0b
jan/25 17:52:35 radvd,warning received Router Solicitation packet with invalid hoplimit=1
jan/25 17:52:35 radvd,warning source-address=fe80::d620:b0ff:fe80:ef0b
jan/25 17:53:14 dhcp,info dhcp1 deassigned 192.168.0.147 for 18:B4:30:00:07:60 02AA01AC261305C2
jan/25 17:53:15 dhcp,info dhcp1 deassigned 192.168.0.165 for 30:8C:FB:F7:95:11
jan/25 17:53:15 dhcp,info dhcp1 assigned 192.168.0.165 for 30:8C:FB:F7:95:11
jan/25 17:53:24 radvd,warning received Router Solicitation packet with invalid hoplimit=1
jan/25 17:53:24 radvd,warning source-address=fe80::d620:b0ff:fe85:fc6f
jan/25 17:53:51 dhcp,info dhcp1 assigned 192.168.0.143 for 5C:5B:35:50:0A:9B AP43-LivingRoom
jan/25 17:53:54 radvd,warning received Router Solicitation packet with invalid hoplimit=1
jan/25 17:53:54 radvd,warning source-address=fe80::5e5b:35ff:fe50:a9b
jan/25 17:54:03 dhcp,info dhcp1 deassigned 192.168.0.137 for F8:10:93:D6:9B:87 JohnsiPone12Pro
jan/25 17:55:31 system,error,critical login failure for user admin from 192.168.0.42 via web
jan/25 17:55:34 system,info,account user admin logged in from 192.168.0.42 via web
jan/25 17:57:30 system,error,critical login failure for user admin from 192.168.0.42 via web
jan/25 17:57:33 radvd,warning received Router Solicitation packet with invalid hoplimit=1
jan/25 17:57:33 radvd,warning source-address=fe80::d620:b0ff:fe80:ef0b
jan/25 17:57:41 system,info,account user admin logged in from 192.168.0.42 via web
jan/25 17:59:51 dhcp,info dhcp1 deassigned 192.168.0.165 for 30:8C:FB:F7:95:11
jan/25 17:59:51 dhcp,info dhcp1 assigned 192.168.0.165 for 30:8C:FB:F7:95:11
jan/25 18:00:04 dhcp,warning Detected conflict by ARP response for 192.168.0.144 from 40:CB:C0:E6:FF:80
jan/25 18:01:03 system,info,account user admin logged out from 192.168.0.42 via web
jan/25 18:01:07 dhcp,info dhcp1 deassigned 192.168.0.165 for 30:8C:FB:F7:95:11
jan/25 18:01:07 dhcp,info dhcp1 assigned 192.168.0.165 for 30:8C:FB:F7:95:11
jan/25 18:01:14 radvd,warning received Router Solicitation packet with invalid hoplimit=1
jan/25 18:01:14 radvd,warning source-address=fe80::d620:b0ff:fe85:fc6f
jan/25 18:02:03 system,info,account user admin logged out from 192.168.0.42 via web
jan/25 18:02:06 radvd,warning received Router Solicitation packet with invalid hoplimit=1
jan/25 18:02:06 radvd,warning source-address=fe80::d620:b0ff:fe85:fc6f
jan/25 18:02:09 dhcp,info dhcp1 assigned 192.168.0.136 for 50:14:79:19:6D:92 iRobot-4F7456418E1E4F7BBB1C344781A24C46
jan/25 18:02:53 dhcp,info dhcp1 deassigned 192.168.0.165 for 30:8C:FB:F7:95:11
jan/25 18:02:53 dhcp,info dhcp1 assigned 192.168.0.165 for 30:8C:FB:F7:95:11
jan/25 18:03:00 radvd,warning received Router Solicitation packet with invalid hoplimit=1
jan/25 18:03:00 radvd,warning source-address=fe80::d620:b0ff:fe85:fc6f
jan/25 18:03:30 radvd,warning received Router Solicitation packet with invalid hoplimit=1
jan/25 18:03:30 radvd,warning source-address=fe80::d620:b0ff:fef1:195
jan/25 18:03:31 radvd,warning received Router Solicitation packet with invalid hoplimit=1
jan/25 18:03:31 radvd,warning source-address=fe80::d620:b0ff:fef1:195
jan/25 18:03:33 system,info,account user admin logged in from 192.168.0.42 via web
jan/25 18:03:51 dhcp,info dhcp1 deassigned 192.168.0.143 for 5C:5B:35:50:0A:9B AP43-LivingRoom
jan/25 18:06:03 system,info,account user admin logged out from 192.168.0.42 via web
jan/25 18:06:25 system,error,critical login failure for user admin from 192.168.0.42 via web
jan/25 18:06:27 system,info,account user admin logged in from 192.168.0.42 via web
jan/25 18:07:00 system,info,account user admin logged out from 192.168.0.42 via web
jan/25 18:07:03 system,info,account user admin logged in from 192.168.0.42 via web
jan/25 18:07:05 system,info,account user admin logged out from 192.168.0.42 via web
jan/25 18:07:08 system,info,account user admin logged in from 192.168.0.42 via web
jan/25 18:07:30 dhcp,info dhcp1 deassigned 192.168.0.131 for D4:20:B0:85:FC:6F AP12-Bedroom
jan/25 18:07:49 dhcp,info dhcp1 deassigned 192.168.0.165 for 30:8C:FB:F7:95:11
jan/25 18:07:50 dhcp,info dhcp1 assigned 192.168.0.165 for 30:8C:FB:F7:95:11
jan/25 18:08:53 radvd,warning received Router Solicitation packet with invalid hoplimit=1
jan/25 18:08:53 radvd,warning source-address=fe80::5e5b:35ff:fe50:a9b
jan/25 18:09:15 radvd,warning received Router Solicitation packet with invalid hoplimit=1
jan/25 18:09:15 radvd,warning source-address=fe80::d620:b0ff:fe80:ef0b
jan/25 18:09:27 radvd,warning received Router Solicitation packet with invalid hoplimit=1
jan/25 18:09:27 radvd,warning source-address=fe80::d620:b0ff:fe85:fc6f
jan/25 18:09:55 dhcp,info dhcp1 deassigned 192.168.0.170 for 00:19:B8:09:80:14 span-gateway
jan/25 18:09:55 dhcp,info dhcp1 assigned 192.168.0.170 for 00:19:B8:09:80:14 span-gateway
jan/25 18:10:26 dhcp,info dhcp1 deassigned 192.168.0.165 for 30:8C:FB:F7:95:11
jan/25 18:10:26 dhcp,info dhcp1 assigned 192.168.0.165 for 30:8C:FB:F7:95:11
jan/25 18:10:47 dhcp,info dhcp1 assigned 192.168.0.131 for D4:20:B0:85:FC:6F AP12-Bedroom
jan/25 18:11:31 dhcp,info dhcp1 assigned 192.168.0.143 for 5C:5B:35:50:0A:9B AP43-LivingRoom
jan/25 18:11:59 dhcp,info dhcp1 assigned 192.168.0.166 for 18:B4:30:8B:50:06 Nest-5006
jan/25 18:12:33 system,info,account user admin logged out from 192.168.0.42 via web
jan/25 18:13:05 system,error,critical login failure for user admin from 192.168.0.42 via web
jan/25 18:13:07 system,info,account user admin logged in from 192.168.0.42 via web
jan/25 18:13:14 dhcp,info dhcp1 assigned 192.168.0.147 for 18:B4:30:00:07:60 02AA01AC261305C2
jan/25 18:13:26 dhcp,info dhcp1 deassigned 192.168.0.139 for D4:20:B0:F1:01:95 AP45-Office
jan/25 18:13:33 system,info,account user admin logged out from 192.168.0.42 via web
jan/25 18:14:21 system,error,critical login failure for user admin from 192.168.0.42 via web
jan/25 18:14:24 system,info,account user admin logged in from 192.168.0.42 via web
jan/25 18:14:26 system,info dhcp server dhcp1 changed by admin
jan/25 18:14:33 system,info,account user admin logged out from 192.168.0.42 via web
jan/25 18:14:39 system,info dhcp server dhcp1 changed by admin
jan/25 18:14:41 system,info dhcp server dhcp1 changed by admin
jan/25 18:16:42 dhcp,info dhcp1 deassigned 192.168.0.165 for 30:8C:FB:F7:95:11
jan/25 18:16:42 dhcp,info dhcp1 assigned 192.168.0.165 for 30:8C:FB:F7:95:11
jan/25 18:16:47 dhcp,warning Detected conflict by ARP response for 192.168.0.148 from 00:1D:63:27:9F:D7
jan/25 18:16:50 dhcp,info dhcp1 assigned 192.168.0.139 for D4:20:B0:F1:01:95 AP45-Office
jan/25 18:16:56 radvd,warning received Router Solicitation packet with invalid hoplimit=1
jan/25 18:16:56 radvd,warning source-address=fe80::d620:b0ff:fef1:195
jan/25 18:18:38 dhcp,info dhcp1 deassigned 192.168.0.170 for 00:19:B8:09:80:14 span-gateway
jan/25 18:18:38 dhcp,info dhcp1 assigned 192.168.0.170 for 00:19:B8:09:80:14 span-gateway
jan/25 18:19:34 radvd,warning received Router Solicitation packet with invalid hoplimit=1
jan/25 18:19:34 radvd,warning source-address=fe80::d620:b0ff:fef1:195
jan/25 18:19:35 radvd,warning received Router Solicitation packet with invalid hoplimit=1
jan/25 18:19:35 radvd,warning source-address=fe80::d620:b0ff:fef1:195
jan/25 18:19:36 radvd,warning received Router Solicitation packet with invalid hoplimit=1
jan/25 18:19:36 radvd,warning source-address=fe80::d620:b0ff:fef1:195
jan/25 18:19:42 system,error,critical login failure for user admin from 192.168.0.42 via web
jan/25 18:21:31 dhcp,info dhcp1 deassigned 192.168.0.143 for 5C:5B:35:50:0A:9B AP43-LivingRoom
jan/25 18:21:58 dhcp,info dhcp1 deassigned 192.168.0.165 for 30:8C:FB:F7:95:11
jan/25 18:21:58 dhcp,info dhcp1 assigned 192.168.0.165 for 30:8C:FB:F7:95:11
jan/25 18:21:59 dhcp,info dhcp1 deassigned 192.168.0.166 for 18:B4:30:8B:50:06 Nest-5006
jan/25 18:22:15 radvd,warning received Router Solicitation packet with invalid hoplimit=1
jan/25 18:22:15 radvd,warning source-address=fe80::d620:b0ff:fef1:195
jan/25 18:22:16 radvd,warning received Router Solicitation packet with invalid hoplimit=1
jan/25 18:22:16 radvd,warning source-address=fe80::d620:b0ff:fef1:195
jan/25 18:22:17 radvd,warning received Router Solicitation packet with invalid hoplimit=1
jan/25 18:22:17 radvd,warning source-address=fe80::d620:b0ff:fef1:195
jan/25 18:22:17 dhcp,info dhcp1 deassigned 192.168.0.170 for 00:19:B8:09:80:14 span-gateway
jan/25 18:22:17 dhcp,info dhcp1 assigned 192.168.0.170 for 00:19:B8:09:80:14 span-gateway
jan/25 18:22:34 radvd,warning received Router Solicitation packet with invalid hoplimit=1
jan/25 18:22:34 radvd,warning source-address=fe80::d620:b0ff:fef1:195
jan/25 18:22:43 dhcp,info dhcp1 deassigned 192.168.0.165 for 30:8C:FB:F7:95:11
jan/25 18:22:43 dhcp,info dhcp1 assigned 192.168.0.165 for 30:8C:FB:F7:95:11
jan/25 18:22:46 radvd,warning received Router Solicitation packet with invalid hoplimit=1
jan/25 18:22:46 radvd,warning source-address=fe80::d620:b0ff:fe85:fc6f
jan/25 18:22:56 radvd,warning received Router Solicitation packet with invalid hoplimit=1
jan/25 18:22:56 radvd,warning source-address=fe80::d620:b0ff:fef1:195
jan/25 18:23:14 dhcp,info dhcp1 deassigned 192.168.0.147 for 18:B4:30:00:07:60 02AA01AC261305C2
jan/25 18:23:21 radvd,warning source-address=fe80::d620:b0ff:fe85:fc6f
jan/25 18:23:21 radvd,warning source-address=fe80::d620:b0ff:fef1:195
jan/25 18:23:47 dhcp,info dhcp1 assigned 192.168.0.143 for 5C:5B:35:50:0A:9B AP43-LivingRoom
jan/25 18:23:52 radvd,warning received Router Solicitation packet with invalid hoplimit=1
jan/25 18:23:52 radvd,warning source-address=fe80::5e5b:35ff:fe50:a9b
jan/25 18:24:03 radvd,warning received Router Solicitation packet with invalid hoplimit=1
jan/25 18:24:03 radvd,warning source-address=fe80::d620:b0ff:fe85:fc6f
jan/25 18:24:09 dhcp,info dhcp1 deassigned 192.168.0.165 for 30:8C:FB:F7:95:11
jan/25 18:24:09 dhcp,info dhcp1 assigned 192.168.0.165 for 30:8C:FB:F7:95:11
jan/25 18:24:13 radvd,warning received Router Solicitation packet with invalid hoplimit=1
jan/25 18:24:13 radvd,warning source-address=fe80::d620:b0ff:fef1:195
jan/25 18:24:22 system,error,critical login failure for user admin from 192.168.0.42 via web
jan/25 18:24:25 system,info,account user admin logged in from 192.168.0.42 via web
jan/25 18:24:32 system,info config changed by admin
jan/25 18:24:35 system,info config changed by admin
jan/25 18:26:06 system,error,critical login failure for user admin from 192.168.0.42 via web
jan/25 18:26:08 system,info,account user admin logged in from 192.168.0.42 via web
jan/25 18:26:16 system,info config changed by admin
jan/25 18:26:31 interface,info sfp-sfpplus1 link down
jan/25 18:27:06 interface,info ether1 link down
jan/25 18:27:06 dhcp,info dhcp-client on ether1 lost IP address 174.160.185.250 - lease stopped locally
jan/25 18:27:33 system,info,account user admin logged out from 192.168.0.42 via web
jan/25 18:32:12 system,info device changed by admin
jan/25 18:32:12 bridge,info "bridge1" mac address changed to DC:2C:6E:28:E4:48
jan/25 18:45:48 interface,info sfp-sfpplus1 link up (speed 10G, full duplex)
jan/25 18:48:35 system,info pool default-dhcp removed by admin
