I need the SFP+ module from my RB5009. Is the port hot-pluggable, or do I have to shut down the router so I can remove the module?
br, Richard
It is hot-pluggable
hi
had a strange issue with th 5009 PoE Version lately in combination with a S+RJ10
when i plugged it IN the router rebooted instantly
when unplugging the S+RJ10 nothing happens
it did not matter if the SFP+ port was enabled or disabled beforehand
had no issues with other modules from “skylane” or “10GTek” so far
thx for the infos. i will shutdown the router
