RB5009 VLAN initial setup
Hello world!
I’m struggling to setup an RB5009 with VLAN. I tried to follow the examples from the manual. Unfortunately, I cannot make it work.
My attempt so far is:
  • use the latest firmware
  • start from factory settings
  • create a management port (ether8)
  • create a first VLAN (194) on bridge port ether5, access port
  • make the RB5009 reachable on ether5, IPv4 (address 10.126.194.1/24)
  • setup DHCP in VLAN
The result on a client machine attached to ether5 is:
  • no dhcp address assignment
  • when trying with a manually set IP address, I cannot reach (ping) the RB5009
  • wireshark on the client sees:
  • STP, CDP traffic from RB5009
  • ICMPv6, DHCP, MDNS traffic from the client machine
  • RB5009 sees the MAC of the client machine in Bridge > Hosts
I would appreciate any help. :slight_smile:
Kind regards,
Timo
# 1970-01-06 20:04:05 by RouterOS 7.13.5
# software id = TFGT-4B36
# model = RB5009UG+S+
# serial number = x
add admin-mac=REDACTED auto-mac=no comment=defconf frame-types=admit-only-vlan-tagged name=bridge vlan-filtering=yes
/interface vlan
add interface=bridge name=vlan-og-main vlan-id=194
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=mgmt ranges=192.168.89.220-192.168.89.239
add name=og-main ranges=10.126.194.193-10.126.194.254
add address-pool=mgmt interface=ether8 name=mgmt server-address=192.168.88.2
add address-pool=og-main interface=vlan-og-main name=og-main server-address=10.126.194.1
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged interface=ether5 pvid=194
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add interface=ether8 list=LAN
add interface=vlan-og-main list=LAN
add address=192.168.89.1/24 interface=ether8 network=192.168.89.0
add address=10.126.194.1/24 interface=vlan-og-main network=10.126.194.0
/ip dhcp-client
add address=10.126.194.0/24 dns-server=10.126.194.1 gateway=10.126.194.1 netmask=24
add address=192.168.89.0/24 dns-server=192.168.89.1 gateway=192.168.89.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" dst-port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
The de facto guideline for setting up VLANs on ROS:
Read, digest, think it over.
Reread, apply, think it over.
Rinse and repeat until it all sinks in :smiley:
Thank you!
The missing piece in my setup was to add the bridge itself explicitly to VLAN 194, tagged, with
/interface bridge vlan
add bridge=bridge tagged=bridge vlan-ids=194
Also if not using IPV6, disable it and remove all the firewall address lists and firewall rules…
https://www.youtube.com/watch?v=4Z32oOPqCqc&t=787s
thank you – I plan to add IPv6 as the next step now :slight_smile:
You are braver than I.
I actually looked at your config and I am surprized anything is working…
First of, if you are going to use vlans across more than one port as well as other subnets, its best too create vlans for each subnet.
Then we are dealing with apples and apples and everything is clear and plays nice together.
Unfortunately you have a mixed bag of fruit and some of that fruit is rotten.
For example.
you clearly want a general subnet, and one would assume associated with the bridge (which I would change to a vlan asap).
Lets look at the evidence…
First you have a single vlan, and that is attached to the bridge… all good so far
/interface vlan
Then you have two POOLS for dhcp, one for the vlan and one for the management ( assuming this is the bridge subnet you want to have )
Then you have two dhcp-servers, and this is where things go off the rails… You assign the management pool to ether8, and not the bridge.
So I am thinking. EITHER the interface is wrong (not ether8),, OR you forgot to have a SUBNET pool for the bridge ?? Im assuming you forgot about a bridge pool and bridge dhcp server then.
In bridge ports, things get more confusing… I can understand the vlan going out untagged on ether5 and possibly
going out as tagged over ports 2-4,7,sfpplus1 ( need to see bridge vlans to confirm) BUT…
ETHER6 makes no sense… you have frames setup as if its an access port but no PVID???
Next you only have two IP addresses articulated… the vlan address, and the ether8 management address.
But where is the bridge associated address???
I note that bridge dhcp server network also only contains entries for the management network and the vlan subnet. Besides potentially missing subnet, my concern is the addition of netmask to the rule.
If you entered that remove, it is not required…
Easily fixed.
add vlan11 to the bridge
create a pool for it, dhcp-server, dhcp-server network, ip address.
then on bridge port assign access ports pvid11 if required to 2-4,7 spffplus1 or the applicable ports etc…
AKA the bridge does no dhcp etc… easy peasy.
Put it on a “someday/maybe” list. Then at least you can decide not to look at it :laughing:
(same here BTW)
