RB5009 will not complete boot process if my PC is connected to ether1
Hi folks, so I upgraded in 2021 to an RB5009 for 2.5Gb/s support from my PC to my server which is on 10Gb/s. Ergo, my PC is on ether1 and the server is on sfp-sfpplus1 (10Gb/s via DAC)
Whenever I upgrade RouterOS, the RB5009 fails to complete the boot process if my PC is connected to ether1. It sits there - forever - with a dim LED on port 2 but no other lights other than the blue power LED. As soon as I remove my PC from ether1, the boot process completes. I can then reconnect to ether1 and the router stays up (until next reboot).
Has anyone seen this behaviour? I have searched for this issue and I can’t find it, but perhaps my search terms are wrong.
I seem to have fixed this, but I am not sure exactly what the fix was. However, it does seem related to netboot, in that the link is stuck in a weird state which was stopping the boot process from completing in the firmware.
One of the following things fixed the issue:
  • Upgrading the firmware to 7.2.3
  • Changing ether1 from only advertising 2.5Gbs to advertising 2.5Gbs and 1000Mbs
  • Turning off as much of the weird and esoteric Wake On LAN stuff on the network driver for my PC.
I’m leaning towards one of the first two items, as when it’s working the link light for ether1 comes on and the router then completes its boot process.
Hello, I have this similar problem with my router from the beginning. I’m using PoE which is also in bonding (2 cables). After upgrade, router never boots up and has to be disconnected and connected only one wire. Thats very sad and problematic. I’m using only 1 Gbps and it’s connected from switch. Problem still exists with RouterOS 7.8.
Start moving to 7.11.2 (or 7.12 beta3).
If problem still persists, create supout.rif and make ticket to support@mikrotik.com including the supout file.
Hello, I have this similar problem with my RB5009 since the beginning. I was thinking that problem is that I have connected PoE and also normal power adapter, but it is not booting even with only power adapter after software reboot. I have to disconnected it and connect again and it will boot. I've read I should update also routerboot, I will try it. But routeros is latest.
@Dacesilian
You will need to post some more details, which interfaces are used, what they are connected to, etc.
Using both PoE and power adapter should make no difference anyway, only one power source is used even if more than one is connected.
And yes routerboot should always be aligned to the RouterOS version but I don't believe that it will make a difference in your case.
I would happily add any details you need:)
RB5009 — RB5009UG+S+IN, RouterOS 7.23.3 stable.
Interface Link speed
`ether1` 2.5 Gbps
`ether3` 1 Gbps
`ether5` 1 Gbps
`ether6` 100 Mbps
`ether7` 100 Mbps
`ether8` 1 Gbps
VLANs, firewall. Now powered only by stock power adapter.
