I have a RB532 that seems to be dead from yesterday night. I upgrade to 3.30 and all was OK. I updated the licence and in this reboot the box didn’t bootup anymore.
I have connected via console and this is the message
RouterBOOT booter 2.9
RouterBoard 532A
CPU frequency: 399 MHz
Memory size: 64 MB
Press any key within 2 seconds to enter setup..
loading kernel from nand... OK
setting up elf image... OK
jumping to kernel code
Kernel panic - not syncing: No init found. Try passing init= option to kernel.
I press the key but it seems to be hung during 1 minute or so and after this I got this Kernel Panic. Of course can’t make a net install becouse I get this error when a key is pressed.
I’ve got a RB532 here which simply doesn’t output anything on the serial port. Tried booting with button S1 pressed (to boot from backup BIOS) and still nothing. The blue & orange LED’s just stay lit. Board doesn’t beep or respond on any of the ports.
Any help or links to documents or troubleshooting tutorials would be appreciated. Thanks.
