As I read in the SUPPORTED HARDWARE list, it is stated that MT supports ZTE MF-622.
As ZTE MF-622 uses USB connection, how can I use such device with RB532A ?
Thanks a lot
Cheers
Thanks a lot
Cheers
you can’t, because this routerboard doesn’t have an USB connector
Hi NORMIS,
Which RouterBoard that has a USB port that I can use with ZTE MF-622 ???
the only RouterBOARD that has a USB port right now, is the RouterBOARD 230
