rb750g - ports 1-5 set to switch 0, need 2-5 on sw1
I’m fairly new to configuring Microtik Routers, and I just spent 3 hours reading documents and googling for an answer but I could not find one for this problem.
I bought a rb750G and it came with no config at all, so I manually configured everything and now it works as a basic router but I cant get the ethernet ports 3-5 to talk with port 2. 3-5 are set to slaves of port 2, but all interfaces are set to switch 0, and I believe 2-5 should be switch 1.
How do I change them?
Alternatively, is there a place I can download a good config to set it up as a basic router if I can’t change them for some reason?
http://klseet.com/index.php?option=com_content&view=article&id=51&Itemid=49
Found a default config file, I’m going that route, since I didn’t have the “default config” from the factory that it was supposed to have I’m going this route.
Set config to default with / system reset-configuration which will load the default script
