Please help, i have a bullet2hp acting as an ap/wds and i want to use the mikrotik rb750g with userman as the control system for those who access the network via the bullet. Network mode is bridge for the bullet.
Can anyone please give me a detailed procedure of how to do this?
I suggest you to use the 750G as a pppoe server and validate users via a radius server.
You can implement a very simple radius server with radiusd, mysql and snmp check for single user control (double login check).
Don’t forget to implement appropiate filters on AP’s.
I have an ISP with 1000’s active users on peak hours with with topology.
Thanks a lot. I am a small wisp, and I achieved this using just the router (I don’t want to use a computer at the moment) Hotspot+Radius+Userman.
I simply use the APs working as Access point WDS, and give the ip ranges as the router… and default gateway is the router address. for now this works ok.
