RB750P-PB
Oh c’mon guys, why do even bothering to release this crap, while we had 750UP ? We now need to power Gbit equipment, not the FE anymore. Or at least 1 GBE port for backhouls. This year is to move to Gbit backhouls. When mikrotik is planning to release such product? Just dont do that mistakes that ubnt did with TS5/8 tiny small buffer that is not capable to forward good throuhtput from 1000 to 100mb/s…
http://routerboard.com/RB260GSP
but no gig with poe
This is not RouterOS device…
Yes, it is! It is a very similar to a RB750UP in an outdoor case
I was talking about RB260GSP :slight_smile:
So normis, please reveal when mikrotik going to release Gbit poe RB ?
Sorry, my mistake.
Yes, We are working on Gbit PoE out devices.
OK, good news. What size of buffer for switching is provided?
It is gigabit with POE.
but
Please make input voltage 12-57V. Thanks
Thank you Mikrotik!!!
I hope these are 802.3af :slight_smile:
i’m sorry if OOT,
any solution for wireless dual band AC router box?
when does mikrotik make 951G-52HPACD ? :smiley:
I have 2 new 750P-PB and both of them will not power up a Mikrotik or Tranzeo device.
It will work ok on a Ubiquity.
I get “short curcit” on all the RB’s.
I tried a New SXT Lite5, RB411 and a RB912UAG-5HPnD.
When I plug in a 750UP they all work fine.
Try set:
/interface ethernet poe settings set ether1-poe-in-long-cable=yes
Thank you.
Setting the long cable worked.
