Hi
RB750UP running 5.21
I have set 3, 4, 5 to master switch 2.
Running a rb1000 on port 4 and 5. I can ping from rb1000 to rb1000 via 750up.
But the interfaces in the rb750up does not show any traffic ?
Hi
Switched traffic does not go to CPU so it is not accounted. It is possible to count traffic only if it reaches CPU.
so its should be 0 bps on the interfaces? not even on the master interface?
You can still see some stats on switch chip ports if you run following commands:
/interface ethernet print stats
/interface ethernet switch port print stats
driver-tx/rx bytes/packets are not counted for switched ports. These values are also ones used to show stats in winbox.
For example ether3 is slave port. As you can see it has no driver stats, but you can still see total received sent byte count and number of packets.
[admin@bumba] /interface ethernet> print stats interval=1
name: sfp1 ether1 ether2 ether3 ether4 ether5 ether6 ether7 ether8 ether9 ether10
driver-rx-byte: 8 358 035 777 0 44 510 530 712 0 0 0 0 0 0 0 0
driver-rx-packet: 21 769 421 0 94 732 519 0 0 0 0 0 0 0 0
driver-tx-byte: 641 297 299 172 77 131 276 811 172 172 92 264 172 264 284 172
driver-tx-packet: 4 364 092 2 104 966 116 2 2 1 3 2 3 3 2
rx-bytes: 8 446 686 971 0 88 504 892 076 5 830 959 587 0 0 0 0 0 0 0
rx-too-short: 0 0 0 0 0 0 0 0 0 0 0
rx-64: 5 654 636 0 606 156 99 430 0 0 0 0 0 0 0
rx-65-127: 7 711 082 0 29 198 669 31 156 713 0 0 0 0 0 0 0
rx-128-255: 2 752 707 0 29 283 638 22 967 302 0 0 0 0 0 0 0
rx-256-511: 1 137 006 0 7 595 603 102 586 0 0 0 0 0 0 0
rx-512-1023: 208 516 0 2 103 233 138 465 0 0 0 0 0 0 0
rx-1024-1518: 4 306 509 0 51 793 549 191 208 0 0 0 0 0 0 0
rx-1519-max: 0 0 0 0 0 0 0 0 0 0 0
rx-too-long: 0 0 0 0 0 0 0 0 0 0 0
