RB750up PPPOE Problem?
hi..i just return from my OS version to 750up router…but im having issues for my ADSL connections …i do not know why this…
on other hand my OS version i did not have this issue …same times but not like this everyday connection drops over 50 times…
But on a safe side i call my ADSL comp and make a line test…they said i did not have any internal or external issue in the line…So must be in the router problem…
beside this issue everything is working fine…
if i go system>routherboard>>>current frimware 2.37 showing…
anything i can do solve this problem pls …???
Jan/18/2014 01:55:36 pppoe ppp info ADSL-Pppoe: initializing…
Jan/18/2014 01:55:36 pppoe ppp info ADSL-Pppoe: dialing…
Jan/18/2014 01:55:36 pppoe ppp info ADSL-Pppoe: authenticated
Jan/18/2014 01:55:36 pppoe ppp info ADSL-Pppoe: connected
Jan/18/2014 01:55:36 system info dns changed
Jan/18/2014 02:08:18 pppoe ppp info ADSL-Pppoe: terminating…
Jan/18/2014 02:08:18 pppoe ppp info ADSL-Pppoe: disconnected
Jan/18/2014 02:08:18 pppoe ppp info ADSL-Pppoe: initializing…
Jan/18/2014 02:08:18 pppoe ppp info ADSL-Pppoe: dialing…
Jan/18/2014 02:08:18 pppoe ppp info ADSL-Pppoe: authenticated
Jan/18/2014 02:08:18 pppoe ppp info ADSL-Pppoe: connected
Jan/18/2014 02:08:18 system info dns changed
What version of routerOs has the routerboard?
Try with upgrade to 6.10
its old??? do i need a update pls…??
You may update the router, no problem.
ths for ur reply..
i have download routeros-mipsbe-6.10.npk …
so i can just drop to using winbox >>files…
yes…then just need to reboot…do i lose my current settings like Firewall-nat-interfaces so on???
if same thing goes wrong there will be a option go back to frimware 2.37
many thx your help again
RouterOs firmware update is not danger to lose your firewall configuration.
No problem with that.
RouterOs update see here but is in dutch follow the printscreens i made
http://www.wirelessinfo.be/index.php/mikrotik/pages/upgrade
RouterOs 2.7 is very old you can that download from mikrotik but is no need
very useful website with pictures wiki…
many many thx…u deserve a karma
Make such a website requires a lot of work.
I work there for over a year.
I make a configuration step for step and make screenshots. enz. Click on the + by karma
If you want may you give me karma i appreciate that.
hi…yes i all ready did…
Thanks my friend
