Any answer from Mikrotik staff about wireless difficulties on RB751-2HnD?
I have been working with Mikrotik equipment for several years and I have never seen wireless problems like RB751-2HnD. It´s a kind of instability all the time on wireless interface.
Signal is good, the coverage zone is good as well.
But, the Tx level in the wireless registration on RB751 is bad, despite the good level of signal (aprox -55). The RX level in RB751 is Ok, like other radios (R2HN and RB711), but TX level is not good.
So, if I run a bandwidth test between RB751 and laptop via wireless I get only 2Mbps, max 5Mbps, no more. CCQ is bad and transfers data velocity is very unstable. The client is disconnected frecuently.
When I change RB751 by other routerboard like RB711, RB411AH with R52HN everything is normal. I can get good download-upload with normal signal level…
I have seen very similar problems with my router. It doesn’t matter a card, running operating system (driver) - especially when the client doesn’t send a long time larger amount of data, TX signal falls and wlan card driver (I think) recognizes the link as disconnected (this fact is sometimes recorded in the router log, but more often seen as a loss of connection on the host). A little bit annoying, comparing to running in this place earlier TP-Link router with DD-WRT there was no objection…
I have tested it with all combinations of chains, even the external antenna, 802.11b, 802.11b/g, …and the others bands.
I have said previously that the same test (same place, same clients, same distance, same 802.11xxxx with others routerboards are Ok, except with RB751. Transfering data is very low because the TX level in routerboard is low…
I can confirm. Seems to work mostly fine as a standard AP, but I have LOADS of problems running it with virtual APS and WDS. Barely able to keep a signal, extremely bad ping times. Both with Ubiquiti and mikrotik on the client side. However, If I use a 751 as a client to a 411, it works flawlessly.
Example:
RB411AR, same setup as a RB751 with a ubiquita nanostation loco client.
same positioning, about 20ft apart in my office, i get 20+mbit throughput and 1ms ping times on the RB411 AR.
On the 7512hnd, I get about 5mbit and 7-20ms ping times.
The bad wireless behavior of RB711UA-2HnD as AP, is a true.
Do you have any solution or will have any solution in short time so we will be able to have our clients happy? Software update or something like that?
I just know that RouterBOARD 751U-2HnD with 400Mhz CPU, 32MB RAM, 5 LAN, built-in 2.4Gh 802b/g/n 2x2 two chain wireless with integrated antennas, 1 MMCX connector, plastic case, 18V AU power supply. Maybe you can change the version or ask the professional person. virtual answering service
Thanks for sharing such an amazing content. I just know that RouterBOARD 751U-2HnD with 400Mhz CPU, 32MB RAM, 5 LAN, built-in 2.4Gh 802b/g/n 2x2 two chain wireless with integrated antennas.Maybe you can change the version or ask the professional person. virtual answering service
