Hi all,
Mikrotik newbie here. Learnt quite a lot from this forum and wiki. Got 1 problem which I couldn’t find a solution to. I can’t set wlan band to 5Ghz in my country i.e. Malaysia. I am sure I have done something wrong here.
Currently using RB751u-2HnD. Router OS v5.16
[admin@MikroTik] /interface wireless> print advanced
0 name=“wlan1” mtu=1500 mac-address=00:0C:42:D5:15:50 arp=enabled disable-running-check=no
interface-type=Atheros 11N radio-name=“000C42D51550” mode=ap-bridge ssid=“Optus Telstra Wifi” area=“”
frequency-mode=manual-txpower country=no_country_set antenna-gain=0 frequency=2412 band=2ghz-b/g/n
channel-width=20/40mhz-ht-above scan-list=default wireless-protocol=any rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-b=1Mbps
basic-rates-a/g=6Mbps max-station-count=2007 distance=dynamic tx-power-mode=default
noise-floor-threshold=default nv2-noise-floor-offset=default periodic-calibration=default
periodic-calibration-interval=60 dfs-mode=none antenna-mode=ant-a wds-mode=disabled
wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no
update-stats-interval=disabled bridge-mode=enabled default-authentication=yes default-forwarding=yes
default-ap-tx-limit=0 default-client-tx-limit=0 proprietary-extensions=post-2.9.25 wmm-support=disabled
hide-ssid=no security-profile=profile1 disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both
compression=no allow-sharedkey=no station-bridge-clone-mac=00:00:00:00:00:00 ht-ampdu-priorities=0
ht-guard-interval=any ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,
mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23
ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-txchains=0 ht-rxchains=0
ht-amsdu-limit=8192 ht-amsdu-threshold=8192 tdma-period-size=2 nv2-queue-count=2 nv2-qos=default
nv2-cell-radius=30 nv2-security=disabled nv2-preshared-key=“” hw-retries=7 frame-lifetime=0
adaptive-noise-immunity=none hw-fragmentation-threshold=disabled hw-protection-mode=none
hw-protection-threshold=0 frequency-offset=0 rate-selection=legacy multicast-helper=default
Using of 5Ghz is allowed in Malaysia. Below link to document saying so from Malaysian Communications and Multimedia Commission.
http://www.skmm.gov.my/link_file/what_we_do/spectrum/pdf/srsp/SRSP534WLAN.pdf
Help please. Thx
