rb951-2n wireless prob
translate by google:
I have a RB951-2n.
In a very simple use of the environment, the the notebook wireless Internet access is frequent nowhere PING ROS gateway, after a few days to find, turned out to be another tablet computer.
Of course, this Android tablet wireless design itself not very good, the software is not very good. Stay connected when its wireless settings to sleep, none of wireless directly Sleep, wireless tablet is not normal in a few minutes, at some point, while in the wireless Internet notebook nowhere PING gateway, until ten seconds, self-healing; open flat or barrier, activate the tablet’s wireless connection, will open as long as the lower plate, laptop immediately connected.
I think as the AP, at least based wireless function to stabilize the domestic flat-panel computer design well, resulting in some ROS does not recognize the data or status, ROS did not do enough robust, If you look at the causes of this phenomenon reason, human control to reproduce this phenomenon, can constitute attacks ROS wireless.
(Of 5.24,5.25 and 6.0RC14 test)
