RBLHG-5nD. What is the maximum length of CAT5e cable
Hi
I need to install RBLHG-5nD - LHG5 (https://mikrotik.com/product/RBLHG-5nD) on a bulding where I need to install 150ft (45m) of CAT 5e indoor cable (Schneider).
The power adapator that is supplied in this product is 24v. Do you think this will have enough power to power the antenna for a 3 miles (5KM) range Point to Point mode?
You can expect it will be working good.
This length is governed by the standard ANSI/TIA 568C.0
Basically, 100m for gigabit ethernet over cat5e. Including patchcords.
However, with POE applications you need to be a little more careful.
Alex
Sent from my Nexus 6P using Tapatalk
