RBM33G + USB console connection to external device
Dear Experts,
I am currently managing network devices which have USB ports for console connection for CLI. Some has USB-B (printer cable) and some has micro USB as console ports.
Problem is I would like to connect to 2-3 devices and the RBM33G only has 1 USB port.
I connect this way:
[admin@MikroTik] > system/serial-terminal usb4 channel=2
Is there a solution to get more USB connections? Is there a hub or some solution you can provde?
Or if you can recommend a newer board which has 2 or even 3 USB ports that would be good too.
Thank you so much !
Connecting USB hub to Mikrotik should work, so you should be able to connect multiple USB devices (mind the power output capability, MT devices usually don’t allow much more than standard 500mA, you may have to use powered USB hub).
I’m not sure though how many serial ports are supported in ROS … could be only a handful?
