RBSXTG-5HPacD-SA - 90deg AP
Hello folks,
I couldn’t find any info about RBSXTG-5HPacD-SA vertical beamwidth , horizontally it is 90 degrees but I’m curious weather I can use it to connect cpes close to the building as well as the far ones.
Thanks in advance.
Dimas
Look at the Antenna Pattern
https://mikrotik.com/product/RBSXTG-5HPacD-SAr2#fndtn-specifications
I would say something about 15 degrees
Thanks for your reply, yes I think the same although I was looking for a precise number.
Kind regards
Dimas
What do those numbers (0 and 90) at the end of figure captions mean? Eg. what’s the difference between “Antenna pattern Vertical 0” and “Antenna pattern Vertical 90”?
