Upgraded from 7.4 to 7.4.1 RB1100AHx4DE, RB2011UiAS2HnD, Groove A-5aHpn, RBD23UGS-5HPacD2HnD. For now everything is ok.
Upgraded from 7.4 to 7.4.1 on RB5009UG+S+IN; everything looks to be working as of the moment.
Upgraded from 7.3.1 to 7.4.1 hap ac2, chateau lte/5g RB953. and Audience all good no issue.
Have (14) CCR-2004-1G-12S+2XS deployed in a ring configuration; using OSPF.
(2) routers failed to re-establish both neighboring links upon installation of the firmware and reboot. Took out 75% of my network. Remote reboots of affected units were successful but did not resolve the issue. Had to visit affected sites for a power cycle of the hardware. Now running normally.
WDS mesh bridge stopped working correctly (clients are somehow not correctly passed between nodes). Using RB4011iGS+5HacQ2HnD-IN and hap ac. Tried to change mesh mode to hwmp, but that one has even more problems in 7.x in general… seems that I will need to downgrade back to 7.4.
Upgraded from 7.3.1 to 7.4.1 RB5009UG+S+, CRS328-24P-4S+Cloud Router Switch, CRS112-8P-4S-IN Cloud Router Switch, hEX PoE RB960PGS, hEXs RB760iGShEXs RB760iGS and chateau 5g all good no issue.
Think I bricked a mAP after upgrading it from 7.4 to 7.4.1. All LEDs are ON (solid) when powered, but device is unresponsive. I’m trying to netinstall, but struggling to put this in netboot mode.
Anyone having the same issue with small devices?
I’ll try later tonight BUT … on the Help page for ROS7 it is stated that version is not be used on device like mAP Lite (mAP and mAP lite are identical as far as resources are concerned).
Only saw that by accident this weekend.
https://help.mikrotik.com/docs/display/ROS/Software+Specifications
Mind you, I use ROS7 on mAP and mAPLite already for quite a while. Never had any problems with it (there are other devices having less resources not being mentioned as ‘unsuitable’)
Very good point, I didn’t know it. And, to be honest, I’m in the same mud, I have been running RouterOS v7 in both devices (mAP and mAP-Lite, I’ve got both) for a while now without problems. This suddenly get all lights solid after rebooting when installing new version. But has been upgrading to V7 since first beta release.
Thanks anyway, don’t want to break yours, so do not apply this just for me!
Regards.
Too late ![]()
7.4.1 is running on the little bugger.
No problems whatsoever.
Time to dust off those netinstall skills, I think.
Which BTW might just be what is needed if you went from ROS6 to ROS7 with lots of intermittent versions.
All updated from 7.4 without issues:
I just did my wAP AC LTE6.
Pretty basic config (travel ap), but so far it looks ok.
Updated my RB5009+UG+S from 7.3.1 towards 7.4.1
No issues so far
hAP ac² - upgraded from 7.4 problem with shutdown back , router only reboot
Loaded 7.4 and 7.4.1 onto four CCR2116’s.
1.7M BGP routes from two peers on one, 1.4M from one peer on the second (both 7.4.1), and 900K aggregated to the one in the middle (7.4). All boxes using upwards of 700MB of RAM, running at a load of ~10% (<2Gbps of traffic).
Fourth router (7.4.1) is the office router. It’s twiddling its thumbs for the most part.
So far, so good.
ROS and firmware updated on Audience.
In log after (re)start:
error while running customized default configuration script: bad command name wireless (line 985 column 25).
CRS1016, AC2 and AC3 updated also, all fine there.
DO NOT UPGRADE REMOTELY. On hAP AC3 the instalation stuck… wifi and internet was working but I could not access the router. Manual reset helped and after reset was router already on 7.4.1
RB4011iGS+5HacQ2HnD-IN + hAP-AC3 update and all seem normal…
hAP ac² update from 7.4 to 7.4.1 went fine. no problems so far.
Does anyone know whether this version supports BGP monitoring via SNMP?
Stuff like uptime and prefix count etc.
