I have Mikrotik Panel AP and i need to reset it at 12:00 AM, i write this is script in schedule :
/system reboot
I make it in schedule as well as im set the clock and NTP client but when reboot the RB at 12:00 am all configuration clock and NTP and schedule is lost to default , please help me if possible .
Thank you , my friend this is config not erase but the i say to you the time and date is reset to default , what the solve for this problem please coz i need reboot the A.P RB433AH every day at time 12am from itself .
my friend , i set all this and work good the A.P Panel Mikrotik but when reboot the router all date and clock is return to default , im apply that and see that .. i think return the date and clock to default coz the A.P don’t available rule for NAT coz the A.P just transfer the service not routing i think that , if you want any config , i will be very happy .
Hi ;
Dear the routerboard should access the internet so the NTP client reach the internet and the routerboard will set the clock and date everytime it reboot.
you need to let the AP access the internet to acheive what you need .
with best regards.
Ahmed
