I have reproduced the problem in a clean installation of ROS 6.40.7 in VirtualBox.
With a static default route, the route to 100.100.100.100/32 is correctly recursively resolved to 172.20.0.1.
> ip address print detail
0 address=172.20.33.1/16 network=172.20.0.0 interface=real-world
actual-interface=real-world
> ip route print detail
0 A S dst-address=0.0.0.0/0 gateway=172.20.0.1
gateway-status=172.20.0.1 reachable via real-world distance=1 scope=30
target-scope=10
1 A S dst-address=100.100.100.100/32 gateway=1.1.1.1
gateway-status=1.1.1.1 recursive via 172.20.0.1 real-world distance=1
scope=30 target-scope=30
2 ADC dst-address=172.20.0.0/16 pref-src=172.20.33.1 gateway=real-world
gateway-status=real-world reachable distance=0 scope=10
But when the default route is dynamic - installed by a client PPPoE connection - the same route to 100.100.100.100/32 is unreachable.
1 D address=5.0.0.5/32 network=5.0.0.0 interface=isp-1 actual-interface=isp-1
0 ADS dst-address=0.0.0.0/0 gateway=isp-1 gateway-status=isp-1 reachable
distance=1 scope=30 target-scope=10
1 ADC dst-address=5.0.0.0/32 pref-src=5.0.0.5 gateway=isp-1
gateway-status=isp-1 reachable distance=0 scope=10
2 S dst-address=100.100.100.100/32 gateway=1.1.1.1
gateway-status=1.1.1.1 unreachable distance=1 scope=30 target-scope=30
3 ADC dst-address=172.20.0.0/16 pref-src=172.20.33.1 gateway=real-world
I downgraded to version 6.30.1 in VirtualBox, and it works as expected in this version: 100.100.100.100/32 is reachable through the remote address of the PPPoE connection.
0 ADS dst-address=0.0.0.0/0 gateway=5.0.0.0
gateway-status=5.0.0.0 reachable via isp-1 distance=0 scope=30
target-scope=10
2 A S dst-address=100.100.100.100/32 gateway=1.1.1.1
gateway-status=1.1.1.1 recursive via 5.0.0.0 isp-1 distance=1 scope=30
target-scope=30
The routes you highlighted are added by ROS itself, when the PPPoE client connection is established. The configuration of the client and the PPPoE server have not been changed.
to disable “add default route” in PPPOE client settings, then create a static route pointing to the IP of the gateway. (Make a comment in this route to check gateway IP if it fails in future, just in case ISP has made IP changes)
Then do Next Hop / Recursive routing via this
*) ppp - use interface name instead of IP as default route gateway;
So this is not a bug, but a feature that has been removed.
Unfortunately, the local and the remote addresses change, so I cannot simply route to the remote address.
I’ll try to work around this problem by setting the remote address in the PPP profile used for my ISP.
