redirect http to https in web fig
hi, tell me how to correctly make a redirect from port 80 to 443, I seem to have set everything up but the redirect does not happen constantly, it’s very suitable for roulette, as luck would have it. I have generated a Let’s Encrypt certificate for Webfig
I’ll upload what I’ve set up today, a little later
AFAIK WebFig doesn’t issue redirects to https. You have to enter https URL yourself. If it bothers you that WebFig is available over http, then disable www service under /ip/service … which will force users to enter https URL (http will simply fail).
Got it, thanks friend for the information!
