redirect https and http sites to a site
I would like https and http sites to be redirected to a site. I have tried several :
/ip firewall nat add chain=dstnat action=dst-nat protocol=tcp dst-port=443 to-addresses=mysite.com to-ports=443 in-interface=bridge
I had done the same for port 80.
I also tried using the web proxy, but it only redirects http and blocks https. (I have looked at the mikrotik documentation).
I don’t know what to do, thanks in advance.
Study the difference between http and httpS.
What ROS can do with DST-NAT is to pass packets to another server.
What ROS (by itself) can not do is to redirect clients to another address. This means that e.g. browser gets new URL and new url is then visible in address bar of the browser.
The way you described intended solution means you’re trying to do the former. There are two potential problems and none are specifically bound to Mikrotik:
  1. the new server has to know it’s replying to requests for the original host name. Which includes installation correct SSL certificate when using HTTPS.
  2. when only doing dst-nat and new target server can reply to client via route which bypasses NAT device, then client will drop packets. The reason is that client thinks it’s talking to MT router (i.e. its IP address) but starts to receive reply packets from end server because end server tries to send replies directly to client. This problem can be avoided by performing also src-nat, making server believe it’s MT router connecting it, so it sends replies to MT router which in turn undoes both nats and delivers client expected replies.
And, as @rextended already wrote: by using NAT you can’t change application protocol … http and https are different beasts and each has its own default port number. You can’t do dst-nat from port 80 to 443 (or vice versa) and expect that communication would succeed.
The above description is a bit theoretical. If you describe what exactly are you trying to achieve (in plain english, don’t bother with configuration code snippets), then you may get some more concrete advice.
aditionally to the difference between http and https, https mechanisms allow web browser and apps to detect when connection is redirected
in recent years most browser and apps using https stop the connection inmediatly they detect the redirection.
because of PKI and certificates is not feasible to avoid redirect detection, is a dead end
Ok, thanks to you I’ve understood why I can’t redirect sites using https.
I’d like to do as here but the explanation is old http://forum.mikrotik.com/t/redirect-all-traffic-from-a-spesific-ip-number-to-a-web-page/79956/1 Are there any alternative solutions for redirecting them?
The solution could be proxy like HAProxy.
@ darci
well, basically - a port is just a port.
but… a port will be in different state if it was used by an app.
some app can take redirection - some with ssl (read: certificate) planted in it can’t take redirection.
there are differences between redirection and interception (proxying).
mostly, generally speaking
  • redirection could mean just redirecting traffic to other location - without terminating those traffic.
  • interception literally mean mitm which terminates traffic on/as if - behalf the remote end . legitimate proxy should have legitimate certificate planted inside that machine to forward the traffic to remote end.
it is ssl job to make sure any kind of proxying unavailable.
examples:
your sshd server config listen on port 22
for internal lan - it will be direct.
but then you need to open this ssh access to enable remote admin from home, you then dstnat your office router port 22345 to 22.
or… internal www at wan ip port 3456 to internal server port 8080.
those are simple redirection. no problem.
but it will be different thing when you do web proxying - for example: squid or haproxy (traffic interceptions).
for non-ssl traffic ie. http, no problem.
but for ssl traffic ie. https. no you can’t. your proxy needs to be ssl termination point - which needs a certificate for itself and other remote server certificate as well - to be able to forward traffic.
hope this helps.
IMO there are two distinct things (on service level), but many people don’t discern them:
  1. forward a request
    In this case original device (transparently) forwards request to another server. The other server returns result and original device passes it to client.
    Client doesn’t know that server, which prepares answer, is not the device it’s talking to.
Prime example of such behaviour is port forwarding. Another example is reverse proxy (for some services this is possible, such as http/https).
2. redirect a request
In this case original device replies to service request with “redirect” message. Next step for client is to finish connection to original device and establish new connection to server, indicated in redirect message.
Prime example of such behaviour is http/https response code 301 moved permanently (or many of 3xx response codes).
So when reading original post in this thread, I understand it according to bullet #2 above. And that can not be done using ROS device because it lacks proper http/http server. As things are, neither can properly do it according to bullet #1 above (except for a very few services, such as http, which don’t allow client to verify server’s authenticity), the reason is the same - lack of proper reverse proxy.
And no, port forwarding is mostly not an option for such task, it doesn’t cover most of different use cases.
Yes you can redirect both HTTP and HTTPS traffic to a specific site.
You can use the following Configure NAT rules to redirect HTTP and HTTPS traffic…
add chain=dstnat protocol=tcp dst-port=80 action=dst-nat to-addresses=desired_ip_address to-ports=80
add chain=dstnat protocol=tcp dst-port=443 action=dst-nat to-addresses=desired_ip_address to-ports=443
Now set up DNS static entries to redirect the domain name to the desired IP address.
/ip dns static
add name=www.mysite.com address=desired_ip_address
add name=mysite.com address=desired_ip_address
Enable NAT reflection to allow internal clients to access the redirected site
add chain=srcnat src-address=internal_network_address dst-address=desired_ip_address action=masquerade
Use browser developer tools to inspect network requests and redirects. you can use online tool such as this tool Redirect checker This can get detail redirection report along with status code.
Try this way, I hope this helps.
