Hi
I have a MikroTik router (RouterOS v7.9) with the goal of creating a specific route to only direct traffic from source address 10.10.2.0/24 to destination 192.168.100.253.
(In 192.168.100.253 I have an openMTCProuter which aggregates several links)
By performing the configuration in the “Routing” section then “Route”:
I don’t ping 1.1.1.1
On the other hand in “IP” then “route”, I can redirect the default route (which I don’t want) to 192.168.100.253
I ping 1.1.1.1
Do you have any ideas to redirect 10.10.2.0/24 to 192.168.100.253 ?
hello wetdarrfr,
is this your setups?
10.10.2.0/24 ---> MT ---> 100.253
https://wiki.mikrotik.com/wiki/Policy_Routing_in_RouterOS_3.x
Hi wiseroute,
That’s it,
My Router1 (Mikrotik):
My Router2 (OpenMTCProuter):
I ping fine one way or the other.
What I would like to do is a default route but taking into account only a source address (10.10.2.0/24).
In order to output 10.10.2.0/24 to the internet by OpenMTCProuter (fiber + 5G) and another network (for example 192.168.0.0/24) to output to the internet by the standard box.
hello
I’m sorry, but your setup and your requirements just doesn’t make sense because your MT only have 100.253 as gateway? or do you have any other gateway on MT?
let us say you make a PBR classifier for 10.10.2.0/24 to go 100.253 as gateway - the other !10.10.2.0/24 too will heading the same gateway? or you just want to Block those !10.10.2.0/24 for accessing the internet?
or do you have any other gateway on MT besides that 100.253? —> this will make sense.
@ werdarrfr,
aaa… you have multiple gateways there.
in that case - this will help
https://wiki.mikrotik.com/wiki/Manual:PCC#Application_Example_-_Load_Balancing
don’t overlook at the load balancing part - but focus on the classifiers to drive 10.10.2.0/24 out to your mtcp router.
I tried to follow https://wiki.mikrotik.com/wiki/Manual:PCC#Application_Example_-_Load_Balancing
to solve my problem
Create a route for the destination 192.168.100.253 with an appropriate gateway:
already OK
Configure a firewall rule to mark traffic coming from the source address 10.10.2.0/24:
/ip firewall mangle add chain=prerouting src-address=10.10.2.0/24 action=mark-routing new-routing-mark=to_OpenMTCProuter
Error message: input does not match any value of new-routing-mark
He only wants “main”
- Add a routing rule to route tagged traffic to destination 192.168.100.253:
add dst-address=0.0.0.0/0 gateway=192.168.100.253 routing-mark=to_OpenMTCProuter
Don’t accept / don’t know the “routing-mark” parameter
(I’m on routerOS 7.9)
So I tried to do something in firewall without any success:
Mangle :
NAT :
Filter rules :
@ werdarrfr
congratulations!
hmm, in case you interested in - what i thought - more simple way…
let us say - MT with 4 ethers :
- mtcp router, LAN : 192.168.100.253/24, WAN : 172.16.1.2/24 (masqueraded)
- lte router, LAN : 192.168.2.2/24, WAN : 172.16.1.3/24 (masqueraded)
- MT,
to-mtcp : 192.168.100.1/24
to-lte : 192.168.2.1/24
to-lan192 : 192.168.1.1/24
to-lan10 : 10.10.2.1/24
requirements :
- lan192 needs to go out to the internet via lte router.
- lan10 needs to go out to the internet via mtcp router.
- both lan192 and lan10 can contact each other.
source-based routing using pbr/dst-nat
# show interfaces
[admin@MT] > interface/print
Flags: R - RUNNING
Columns: NAME, TYPE, ACTUAL-MTU, L2MTU, MAC-ADDRESS
# NAME TYPE ACTUAL-MTU L2MTU MAC-ADDRESS
0 R ether1-lan192 ether 1500 50:00:00:01:00:00
1 R ether2-lan10 ether 1500 50:00:00:01:00:01
2 R ether3-mtcp ether 1500 50:00:00:01:00:02
3 R ether4-lte ether 1500 50:00:00:01:00:03
# ip addresses
[admin@MT] > /ip address/print
Columns: ADDRESS, NETWORK, INTERFACE
# ADDRESS NETWORK INTERFACE
0 192.168.1.1/24 192.168.1.0 ether1-lan192
1 10.10.2.1/24 10.10.2.0 ether2-lan10
2 192.168.100.1/24 192.168.100.0 ether3-mtcp
3 192.168.2.1/24 192.168.2.0 ether4-lte
# default route via mtcp and lte.
# note those ECMP path on mtcp and lte gateway
[admin@MT] > ip route/print
Flags: D - DYNAMIC; A - ACTIVE; c, s, y - BGP-MPLS-VPN; + - ECMP
Columns: DST-ADDRESS, GATEWAY, DISTANCE
# DST-ADDRESS GATEWAY DISTANCE
0 As+ 0.0.0.0/0 192.168.2.2 1
1 As+ 0.0.0.0/0 192.168.100.253 1
DAc 10.10.2.0/24 ether2-lan10 0
DAc 192.168.1.0/24 ether1-lan192 0
DAc 192.168.2.0/24 ether4-lte 0
DAc 192.168.100.0/24 ether3-mtcp 0
# masquerade on both wan interface (mtcp and lte) - for simplicity.
[admin@MT] > ip firewall/nat/add chain=srcnat out-interface=ether3-mtcp action=masquerade
[admin@MT] > ip firewall/nat/add chain=srcnat out-interface=ether4-lte action=masquerade
# pre-pbr ping and traceroute test
# from lan 192.168.1.0/24 to lan 10.10.2.0/24 and to inet (172.16.1.1/32)
lan192> ping 10.10.2.2
84 bytes from 10.10.2.2 icmp_seq=1 ttl=63 time=62.541 ms
84 bytes from 10.10.2.2 icmp_seq=2 ttl=63 time=6.323 ms
84 bytes from 10.10.2.2 icmp_seq=3 ttl=63 time=1.965 ms
84 bytes from 10.10.2.2 icmp_seq=4 ttl=63 time=2.068 ms
84 bytes from 10.10.2.2 icmp_seq=5 ttl=63 time=3.341 ms
lan192> ping 172.16.1.1
84 bytes from 172.16.1.1 icmp_seq=1 ttl=62 time=10.958 ms
84 bytes from 172.16.1.1 icmp_seq=2 ttl=62 time=7.210 ms
84 bytes from 172.16.1.1 icmp_seq=3 ttl=62 time=10.256 ms
84 bytes from 172.16.1.1 icmp_seq=4 ttl=62 time=5.275 ms
84 bytes from 172.16.1.1 icmp_seq=5 ttl=62 time=4.448 ms
lan192> trace 172.16.1.1
trace to 172.16.1.1, 8 hops max, press Ctrl+C to stop
1 192.168.1.1 2.161 ms 1.249 ms 1.716 ms
2 192.168.100.253 14.839 ms 4.361 ms 3.569 ms
3 *172.16.1.1 4.335 ms (ICMP type:3, code:3, Destination port unreachable)
# pre-pbr ping and traceroute test from lan 10.10.2.0/24 to lan 192.168.1.0/24 and to inet (172.16.1.1/32)
lan10> ping 192.168.2.2
84 bytes from 192.168.2.2 icmp_seq=1 ttl=63 time=3.009 ms
84 bytes from 192.168.2.2 icmp_seq=2 ttl=63 time=5.473 ms
84 bytes from 192.168.2.2 icmp_seq=3 ttl=63 time=5.074 ms
84 bytes from 192.168.2.2 icmp_seq=4 ttl=63 time=5.349 ms
84 bytes from 192.168.2.2 icmp_seq=5 ttl=63 time=4.085 ms
lan10> ping 172.16.1.1
84 bytes from 172.16.1.1 icmp_seq=1 ttl=62 time=6.169 ms
84 bytes from 172.16.1.1 icmp_seq=2 ttl=62 time=10.623 ms
84 bytes from 172.16.1.1 icmp_seq=3 ttl=62 time=4.208 ms
84 bytes from 172.16.1.1 icmp_seq=4 ttl=62 time=7.421 ms
84 bytes from 172.16.1.1 icmp_seq=5 ttl=62 time=9.439 ms
lan10> trace 172.16.1.1
1 10.10.2.1 2.170 ms 0.985 ms 1.074 ms
2 192.168.2.2 3.946 ms 11.984 ms 2.309 ms
3 *172.16.1.1 5.542 ms (ICMP type:3, code:3, Destination port unreachable)
# pbr classifiers on MT : 10.10.2.0/24 via mtcp, 192.168.1.0/24 via lte
# creating address-list for local LAN :
[admin@MT] > ip firewall/address-list/print
Columns: LIST, ADDRESS, CREATION-TIME
# LIST ADDRESS CREATION-TIME
0 local 192.168.1.0/24 jul/14/2023 16:28:43
1 local 10.10.2.0/24 jul/14/2023 16:28:50
# dst-nat based pbr
# lan10 to-mtcp
# lan192 to-lte
[admin@MT] > ip firewall/nat/print
Flags: X - disabled, I - invalid; D - dynamic
0 chain=srcnat action=masquerade out-interface=ether3-mtcp
1 chain=srcnat action=masquerade out-interface=ether4-lte
2 chain=dstnat action=dst-nat to-addresses=192.168.100.253 dst-address-list=!local in-interface=ether2-lan10
3 chain=dstnat action=dst-nat to-addresses=192.168.2.2 dst-address-list=!local in-interface=ether1-lan192
# post-pbr traceroute test.
# from lan 192.168.1.0/24 to internet
1 172.16.1.1 1.683 ms 1.401 ms 1.993 ms
2 *172.16.1.1 5.192 ms (ICMP type:3, code:3, Destination port unreachable)
lan192> trace 10.10.2.2
trace to 10.10.2.2, 8 hops max, press Ctrl+C to stop
1 192.168.1.1 2.530 ms 1.710 ms 1.277 ms
2 *10.10.2.2 3.322 ms (ICMP type:3, code:3, Destination port unreachable)
# from lan 10.10.2.0/24 to internet
1 172.16.1.1 1.475 ms 0.960 ms 0.973 ms
2 *172.16.1.1 6.249 ms (ICMP type:3, code:3, Destination port unreachable)
# from lan 10.10.2.0/24 to lan 192.168.1.0/24
lan10> trace 192.168.1.2
trace to 192.168.1.2, 8 hops max, press Ctrl+C to stop
1 10.10.2.1 1.306 ms 1.413 ms 1.755 ms
2 *192.168.1.2 7.687 ms (ICMP type:3, code:3, Destination port unreachable)
# notes :
# - the actual masquerade to the internet handled by those mtcp (192.168.100.253) and lte (192.168.2.2/24) routers.
# - those mtcp and lte uses fixed internal IP address.
hope this helps.
