I’ve done some further investigation, following my earlier post re. unexpected slow response from MikroTik AP (http://forum.mikrotik.com/t/unexpectedly-high-ping-times-to-mikrotik-hap-ac3/155178/1).
Original problem showed intermittent high ping response times (>300mS).
Further investigation shows some unexpected behaviour with the MikroTik device. It appears there may(?) be some regular blocking within router. It could explain the >300mS ping times.
It would be really helpful to understand why I am seeing the >300mS ping times. What could explain the blocking? How could we configure MikroTik AP device to behave better?
Here’s more details about the test & findings.
Test
- Mikrotik hAP ac3 (Model RBD53iG-5HacD2HnD), setup with out-the-box vanilla configuration as Dual-band AP.
- Linux laptop setup next to Mikrotik AP.
- Laptop is only device connecting to AP.
- High volume ping command run continuously, directly to AP IP address:
sudo ping -I <WiFi-interface> -q -s 1200 -c 500 -i '0.001' -D <Router-IP>
- Results logged to file & tidied-up.
Results
In summary:
- Regularly every 10 or 20 seconds there is a large spike in max response time, often >300mS.
- Other response times are good.
In detail:
- First few cycles only shown. More data is available
Timestamp min avg max mdev pipe
2022-02-22 12:58:20 0.688 10.475 256.65 38.012 19
2022-02-22 12:58:20 0.665 0.781 1.675 0.104
2022-02-22 12:58:21 0.698 0.764 1.441 0.064
2022-02-22 12:58:21 0.695 0.762 1.546 0.062
2022-02-22 12:58:22 0.688 0.814 1.317 0.075
2022-02-22 12:58:22 0.707 0.811 1.722 0.082
2022-02-22 12:58:23 0.699 0.767 1.404 0.063
2022-02-22 12:58:23 0.676 0.741 1.328 0.066
2022-02-22 12:58:24 0.704 0.768 1.381 0.070
2022-02-22 12:58:24 0.676 0.748 1.485 0.087
2022-02-22 12:58:25 0.675 0.787 1.663 0.095
2022-02-22 12:58:25 0.662 0.745 1.407 0.085
2022-02-22 12:58:26 0.677 0.804 1.334 0.087
2022-02-22 12:58:26 0.674 0.744 1.579 0.081
2022-02-22 12:58:27 0.674 0.790 1.697 0.104
2022-02-22 12:58:27 0.684 0.812 1.391 0.081
2022-02-22 12:58:28 0.692 0.810 1.370 0.076
2022-02-22 12:58:28 0.667 0.767 1.392 0.083
2022-02-22 12:58:29 0.684 0.769 1.481 0.087
2022-02-22 12:58:29 0.674 0.795 1.481 0.090
2022-02-22 12:58:30 0.665 2.639 126.70 12.376 13
2022-02-22 12:58:31 0.676 0.803 1.215 0.088
2022-02-22 12:58:31 0.676 0.775 1.398 0.084
2022-02-22 12:58:32 0.702 0.789 1.447 0.079
2022-02-22 12:58:32 0.696 0.750 1.340 0.071
2022-02-22 12:58:33 0.685 0.814 1.455 0.078
2022-02-22 12:58:33 0.704 0.785 1.471 0.085
2022-02-22 12:58:34 0.684 0.765 1.855 0.079
2022-02-22 12:58:34 0.696 0.810 1.410 0.078
2022-02-22 12:58:35 0.671 0.815 1.436 0.079
2022-02-22 12:58:35 0.691 0.801 1.521 0.081
2022-02-22 12:58:36 0.664 0.760 1.437 0.102
2022-02-22 12:58:36 0.677 0.785 1.395 0.079
2022-02-22 12:58:37 0.675 0.739 1.360 0.078
2022-02-22 12:58:37 0.684 0.763 1.567 0.067
2022-02-22 12:58:38 0.683 0.803 1.491 0.078
2022-02-22 12:58:38 0.681 0.743 1.388 0.056
2022-02-22 12:58:39 0.703 0.798 1.401 0.073
2022-02-22 12:58:39 0.683 0.775 1.217 0.074
2022-02-22 12:58:40 0.685 0.809 1.447 0.075
2022-02-22 12:58:40 0.677 0.750 1.372 0.063
2022-02-22 12:58:41 0.676 0.932 24.154 1.795 3
2022-02-22 12:58:42 0.696 0.835 9.998 0.418
2022-02-22 12:58:42 0.673 0.794 1.496 0.087
2022-02-22 12:58:43 0.664 0.758 1.366 0.092
2022-02-22 12:58:43 0.708 0.819 1.428 0.083
2022-02-22 12:58:44 0.700 0.775 1.777 0.092
2022-02-22 12:58:44 0.696 0.816 1.468 0.079
2022-02-22 12:58:45 0.674 0.782 1.394 0.098
2022-02-22 12:58:45 0.659 0.757 1.372 0.087
2022-02-22 12:58:46 0.676 0.800 1.495 0.091
2022-02-22 12:58:46 0.682 0.810 1.374 0.082
2022-02-22 12:58:47 0.673 0.756 1.502 0.074
2022-02-22 12:58:47 0.679 0.764 1.393 0.083
2022-02-22 12:58:48 0.674 0.803 1.539 0.090
2022-02-22 12:58:48 0.674 0.762 1.749 0.113
2022-02-22 12:58:49 0.674 0.807 1.433 0.092
2022-02-22 12:58:49 0.674 0.756 1.572 0.098
2022-02-22 12:58:50 0.668 0.751 1.482 0.069
2022-02-22 12:58:50 0.697 0.794 1.345 0.079
2022-02-22 12:58:51 0.696 0.792 1.277 0.079
2022-02-22 12:58:51 0.703 0.797 1.417 0.078
2022-02-22 12:58:52 0.685 1.445 60.218 4.915 7
2022-02-22 12:58:52 0.660 0.761 1.389 0.076
2022-02-22 12:58:53 0.703 0.818 1.510 0.084
2022-02-22 12:58:54 0.699 0.767 1.366 0.058
2022-02-22 12:58:54 0.669 0.727 1.452 0.073
2022-02-22 12:58:55 0.674 0.773 1.441 0.085
2022-02-22 12:58:55 0.685 0.741 1.334 0.061
2022-02-22 12:58:56 0.678 0.769 1.511 0.077
2022-02-22 12:58:56 0.692 0.761 1.525 0.074
2022-02-22 12:58:57 0.687 0.792 1.396 0.078
2022-02-22 12:58:57 0.680 0.782 1.395 0.086
2022-02-22 12:58:58 0.683 0.736 1.603 0.076
2022-02-22 12:58:58 0.681 0.746 1.568 0.072
2022-02-22 12:58:59 0.673 0.729 1.562 0.069
2022-02-22 12:58:59 0.706 0.778 1.404 0.062
2022-02-22 12:59:00 0.677 0.731 1.339 0.057
2022-02-22 12:59:00 0.705 0.808 1.253 0.074
2022-02-22 12:59:01 0.679 0.754 1.641 0.081
2022-02-22 12:59:01 0.686 0.778 1.588 0.073
2022-02-22 12:59:02 0.692 0.799 1.385 0.084
2022-02-22 12:59:02 0.698 0.796 1.484 0.091
2022-02-22 12:59:03 0.692 0.817 1.434 0.084
2022-02-22 12:59:03 0.692 3.085 138.10 13.826 14
