Is there any reliable protocol to synchronize Address-List between mikrotiks in realtime ?
You can do it with API. Write an application that will log in to routers and sync their address lists.
I may be interested in programming something like this, if there is interest in it. Gotta be worth the time, though!
Even Better is to do something like this to the IP pools
omidkosari, do you already synchronize? =)
if not, what kind of synchronization do you need?
you do /ip firewall address-list export file=address-list on source router, then
/tool fetch address=
/import address-list.rsc
on the destination router. This seems to work good for static entries, but I haven’t found a way to capture dynamic entries to file (I could make them static, but I need them to time out after specified time).
yeah! MT guys, is it possible to add an ability to create dynamic entries in address lists? or at least (for a start) to determine expiry time of entry…
Yes i have tried some kind of syncs like a schedule program but i have dynamic address-list gotten via RADIUS so they should be in realtime . so the problem is that the program should be a service (which may have its own problems) and not a schedule type program like mine . and another problem is that i think if we want to sync address-lists via an external program it will made high load on mikrotik because it should always keep eyes on mikrotiks and assume we have long address-lists .
The expire time does not work in my situation because the Dynamic Address-List create right when user authenticates via radius so if it expires there is not a normal way to recreate it and radius does not advertise it in each packet .
not a service, just continually running program
no. you just connect via API, execute ‘/print =follow=’ (or something) command - and RouterOS will send you all changes in lists. almost no load at all
But it does not show Address List removes. it just shows when an address added to address list . am i right ? so how we can determine when an address removes from address list ?
to see changes you can run just 1 command:
/ip/firewall/address-list/print
=follow=1
.tag=adr
as result you will have to keep address list with router *ID numbers, and then you will see ID when address is added, and when address expires, it will show up as
!re
=.id=*5
=.dead=true
.tag=adr
happy syncing ![]()
