remove all static DHCP leases?
I’d like to manage my DHCP static leases outside of the router. (I’ll likely be using a simple text file, containing hostname, IP address, and MAC, but how I store my list doesn’t really matter.)
I can easily turn that list into the “/ip dhcp-server lease add …” commands needed to load them into the server. But if I retire a host, and remove it from my text file, it won’t (easily) be removed from the router by my script. Similarly, if I want to give a host a new address, simply reimporting will result in two leases for that host.
The obvious clean solution would be to simply clear all static leases, and then add them back again.
Is there a way to clear all static leases using the MikroTik console?
use find
this will remove all leases, including dynamic ones
/ip dhcp-server lease remove [find]
something like this to find leases with a specific adress
/ip dhcp-server lease remove [find where where address=insert-ip]
all available options
.dead               agent-circuit-id        dhcp-option-set      radius
.id                 agent-remote-id         disabled             rate-limit
.nextid             allow-dual-stack-queue  dynamic              server
active-address      always-broadcast        expires-after        src-mac-address
active-client-id    block-access            host-name            status
active-mac-address  blocked                 insert-queue-before  use-src-mac
active-server       client-id               last-seen
address             comment                 lease-time
address-lists       dhcp-option             mac-address
No options for finding only static ones or I might be missing something you could use to target just them, seems weird to not have something like that.
Thanks. I certainly wouldn’t want to remove the dynamic ones. I can probably cobble something together, by printing the leases and writing a script to find the ones not marked dynamic. But it’ll be ugly, I can promise you that.
I suppose anyone that wants to manage addresses off-router uses a radius server. I wish there were something in between that and having to use the CLI, though, like maybe reading static lease information from a file. The other alternative is running a separate DHCP server.
/ip dhcp-server lease remove [find where dynamic=no]
You can both print and export to file.
/ip dhcp-server lease export file=dhcp-static
So, that first command does exactly what I was asking for? That’s excellent! Thanks!
paul
