We use bgp for our connections, but as we had only one peer up, we used even Quick Set to them. Now we have 4 peers running to different upstream providers, but when the one, which is set in Quick Set goes down, no other route is automatically working.
How the set things (IP, gateway, Lan IP, …) can be revoked to standard (0.0.0.0) without setting the whole router to factory?
Thank you,
Christian
Apply rule #4 from the rules outlined in The twelve Rules of Mikrotik Club
In short: don’t ever use QuickSet after you configure anything outside of scope of QuickSet. And that includes adding BGP peers in the routing submenu.
Adding: which also means it is best to start again from factory conditions on that one peer.
And then you can be sure no Quickset settings will interfere with your desired config.
Export config before resetting so you have a base line to start from.
Pay close attention to settings which are deviating from default before applying them again.
In case of need, here are a couple spreadsheets that may be useful to compare the two configurations (your existing one against the default after reset):
Thank you for your answer.
It was done 2 years ago and not even by myself…
The question is still, how it can be done?
Thank you,
Christian
Post your configuration, instructions here:
and hopefully some of the more expert members will be able to spot the issue(s) and advise you.
